How many minutes were you driving at this steady state before you recorded?v-janitor wrote: 28 Dec 2019, 17:25 I took some graphs driving (at normal engine temperature, 4th gear about 55 MPH, and 2,500 RPM) of the STFT and LTFT today;
1997 850 NA manual transmission vibration at idle (also sorting out NA EVAP hose routing)
- Has thanked: 2864 times
- Been thanked: 1332 times
5 should be enough to lose any STFT data from acceleration so that it's not mixing with LTFT.
Did you reset ECU?
Weak battery? See this viewtopic.php?t=61256#p314131
Did you reset ECU?
Reason: fixed link
Reason: fixed link
- Has thanked: 1611 times
- Been thanked: 4075 times
Old thread stumble. This was a great thread exposing that the 1997 rear mounted fuel pressure regulation uses an early implementation of the “ return lacking “ FPR system that was used in 1999-
This uses purge line vacuum to regulate fuel pressure and the vacuum hose diagrams under hood might not correspond.
You can search “ return lacking” as it is the official Volvo name for this configuration
