Found out what that was... turns out the CV Axel Boot has a tear and it sprayed grease all over the area. Lucky I saw this in time to fix it before it gets bigger and dirt gets in there and ruins it.oragex wrote: 05 May 2020, 10:05 I seen to see some leak where it points in this picture. Can you take a second look ? That could be a leak from the cam seals, or even from the water pump - the pump is the gear right above where it appears to be wet. The pump has a hole to it, see if anything leaks
How to tell if Timing Belt Service had ever been done ? Topic is solved
- hmsky83
- Year and Model: 2001 S60 & 2002 S60
- Has thanked: 6 times
2001 Volvo S60 2.4T
2002 Volvo S60
2005 Chevy Avalanche
2002 Volvo S60
- 805 Views
Last post by - Pete -
- 26 Replies
- 5007 Views
Last post by Petskoi
- 3789 Views
Last post by CIK7
- 820 Views
Last post by doublebug
- 1068 Views
Last post by Cees Klumper
