94 T5 - could my timing belt been off a tooth? Topic is solved
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
When redoing my timing belt (but only after removing the tensioner) it seemed to me that my timing marks seem odd right now. Could I've been running with the exhaust side 1 tooth of for 7 years without noticing?
How many teeth can the cams benoff w/o causing any damage? Can't be much, I guess.
1996 855 R,
2010 V70 D5,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
2.
3 teeth off is a game over.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
You'll notice the difference when it's timed properly. Mine was off a tooth for years also, then when the interval for replacement was up, voila, ran smoother and a bit more peppy.
Has thanked: 1609 times
Been thanked: 4065 times
If you detune a T5 by one tooth, you get an R !
πŸ˜€
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Also timing belts can stretch, it may have just been that especially if it appeared to be more like 3/4 of a tooth etc.
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Mine was also off by a bit, I didn't do the last replacement myself but shop said so. Also finally made the car perform properly, I did have a thread here because it had no power in high rpm :D
My guess is that there are some people changing them that don't know what they are doing. Doubt it jumped by itself.
850 T5-R '95 auto Image
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
When I replaced my timing belt two years ago I did so very carefully, and yet after double-checking I found it was one tooth off, so I wasn't careful enough. I corrected it before starting the engine. The engine ran better than with the old belt, which I found slightly, slightly longer than the new one. It became noticeable more fuel efficient as well. So perhaps you caused the 'one tooth off' if you did not really check the timing marks before taking off the old belt.
