Ok, so replaced throttle body with junkyard unit. The one that came off the car had part # ending in "53" so FCP's contention I need a "54" appears to be incorrect.
After replacing throttle body idle still lumpy. Sought to do a "TB adaptation" but I must have VIDA Lite because nowhere did I see that as an option.
And, codes getting very much worse. New ones today:
CEM 1A61 Communication with TCM control module signal missing
ECM 510F vehicle speed signal - signal missing
ECM 530B malfunction indicator lamp communication
ECM 91B7 throttle valve -faulty signal
Any ideas?
Just to recap:. New Bosch coils (5) less than 5,000 miles ago. New Volvo turbo plugs, same vintage. New MAF this past Friday (Bosch). Junkyard throttle body (cleaned to spotless) today.
Battery voltage could be a little low since only getting used for short runs.
Interesting: frozen values from initial readout:. "Ambient temperature -107.5 °C." Frozen values, I'll say.
'04 XC Engine Misfiring-Further Updated (Moisture ruled out - possible defective coils, bad MAF) Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4068 times
Okay, noodling on this one.
- E Showell
Could this be a reprise of Sergio's epic failing starter and compromised flex plate thread? Haven't detected any loud booms so far.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
The plot thickens. Just put a multimeter on the battery in the car, while connected to the car. Resting voltage reads 12.26 V.
Which, as I understand it, is an expired battery.
Next stop, battery charger.
'95 855 auto (sold)
'95 855 auto (sold)
Low at 70 degrees F or more
24 hours on the big charger , please
- E Showell
Well, I guess it's really about 55% charge, but lower than I like to see. Five year old Interstate "Megatron" 60 month battery. Not sure of the rated amp hours or CCA.
'95 855 auto (sold)
'95 855 auto (sold)
You caught the Covid “ I can make this battery last “ bug from some one you met with recentlyE Showell wrote: 15 Jun 2020, 20:13 Well, I guess it's really about 55% charge, but lower than I like to see. Five year old Interstate "Megatron" 60 month battery. Not sure of the rated amp hours or CCA.
( my 2013 T5 battery is cranking low , too.)
- E Showell
Ordered a CTek MX5 smart charger and tester. We'll see if the smart charger can help the dumb owner.
'95 855 auto (sold)
'95 855 auto (sold)
Just remembered. The 2004 has a TSB for water intrusion into the CEM. Have you had that mod done?
Researching...looks like it’s 2005 MY issue only.
- 3133 Views
Last post by itsmekirby
- 5976 Views
Last post by chrism
- 2239 Views
Last post by MoVolvos
- 357 Views
Last post by JaredR
- 26 Replies
- 6468 Views
Last post by ChadLee
