FDPP #2
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Yes, I still need one. Mine only has rear fog lights, so I'm assuming it'll work on my car. Thank you.
gnalan
Post by gnalan »
I found this on a Volvo parts website:
"Front spring suspension.
MARKED 4E, 4D, 4F, 5J, 5K, 5P, 7G, 7H, 7J, 15. AF. For marking, see identification plate."
MARKED 1B, 1D, 1E, 1G, 1H, 1K, 1R, 1S, 1V, 1Z, 2X, 2Y, 2Z, 3A, 3B, 4E, 4K, 4J, 4L, 4H, 4P, 4W, 4S, 4R, 4M, 5A, 5M, 5N, 5L, 6F, 9K, 9F, 11, 16, 18. For marking, see identification plate. 2WD. CH -523577."
My identification plate says 4E. Is there a difference between the two that would cause any problems if the replacement strut volvolugnut has doesn't match what I have on the driver's side?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
gnalan, I check the struts this morning and they are not very good. Very minimal resistance to motion in up and down. I don't think you would gain much using these struts. Sorry to get your hopes up.
Someone else have a decent strut?
gnalan
Post by gnalan »
Thank you, volvolugnut, for double checking them. I do appreciate the help from everyone here.
The whole assembly is bad, bearing, spring, bumpstop, bellows, and strut.
Is there anyone from Ohio on here? If so, would you be able to find me a good, complete, strut assembly at a Pick N Pull yard and pull it for me?
We may need to expand the area to draw from for a used spring/strut assembly. These can ship reasonably.
Anyone have one?
gnalan
Post by gnalan »
I wasn't sure what the shipping would cost. I thought trying to find someone in Ohio with parts that we could meet up and make things easier than trying to ship it all.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
I’d need to look, but I think I have one off a V70. Should be the same fitment. Pretty sure I have all but the spring, but let me check. If your spring isn’t cracked (usually if they crack its ~1/2 of a coil off the bottom) just reuse it.
The strut I (think I) have didn’t look the best, but it also didn’t leak & rode fine.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
- Pete -
Post by - Pete - »
Turns out I was wrong.
8667253 A.
Does have spring, spring seat is good, top bearing plate is good.
I don’t know what shipping will run you, but you can have it (and the LSM) for the cost of shipping.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
gnalan
Post by gnalan »
Thank you, I really appreciate all of the help.
gnalan
Post by gnalan »
Quick question. The part number you gave me for the strut doesn't match up with the 4E which is what's on my car. Will that cause me any problems having one side different than the other?
8667253
MARKED 1W, 2L, 2V, 2U, 3C, 3D, 3E, 4D, 4F, 4N, 4Z, 4Y, 5B, 5B, 5C, 5D, 5N, 6J, 6N, 6G, 6E, 7A, 7C, 7B, 7D, 7K, 14. For marking, see identification plate. AWD. CH 523578-.
The LSM I can use, but I'm worried about putting the wrong strut/spring combination on one side and having a different combination on the other side.
