Misfire issues?
Has thanked: 1611 times
Been thanked: 4072 times
jujufly wrote: 28 Feb 2022, 11:32 thanks for your help, i definitely will do what you suggest for me. by the way, do you have recommendation part link for ignition coil and spark plug? i try to search it and not sure if it is fitted or not. i recently bought a air filter for my S80, amazon says it is fitted, when i started to replace it, i realized it could not be fitted, because the filter size is not correct at all :lol: , then i don't trust amazon checking option now.
We recommend our forum sponsors FCP euro and IPD fir parts. This isn’t just because they support us, their service and parts guidance is far above the quagmire of eBay and Amazon.
FCP guarantees parts for life, so if you plan on running your car long term, thst math works out well
Has thanked: 311 times
Been thanked: 818 times
Post by erikv11 »
jujufly wrote: 28 Feb 2022, 13:07 thanks, i just check my car model by VIN number, here is car information
2004 Volvo S80 6 Cylinders 2.9L FI DOHC 178 CID
thank you
https://www.fcpeuro.com/products/volvo- ... a29coilkit
jujufly
Year and Model: 2004 s80
Post by jujufly »
can someone help to verify the fire order for 2004 Volvo S80? is it 124536? now i am trying to switch ignition coil between 5 and 4, but cannot figure which one is #5. thanks.
jujufly
Post by jujufly »
Default
Has thanked: 2207 times
Been thanked: 1852 times
Normally the cylinders are numbered from the timing belt side on engines. If yours is the in-line 6 cylinder engine, then cylinder #1 is the cylinder nearest the timing belt, and then they are numbered 1-6 working from there.
Post by erikv11 »
What Neil said. You don't need to know anything about the firing order to locate and switch around numbered coils. #1 is on the passenger side, #6 is on the driver's.
Also remember each cylinder has a fuel injector and rarely those get clogged or go bad. Coil or spark plug trouble is much more likely.
Firing order is 1-5-3-6-2-4. See the pic illustrating both in this post by RickHaleParker viewtopic.php?t=17832&start=10
01V70XC05S60
Year and Model: 01 V70XC, 05 S602.5t
Post by 01V70XC05S60 »
Hi Gentlemen. You guys and awesome. You've helped me learn, and fix a lot. I have a 2005 S60T awd that has a cylinder 5 misfire. I've replaced MAF, air filter, all 5 coils and plugs. I can hear injector clicking, and I've swapped coils. I put in NGK iridium top grade plugs because I got them free. I also bought aftermarket coils because they swore they are better than the OEM, and modeled after the OEM, but replacing some of the weaker areas with higher quality material. My cheap scanner is only reading the #5 misfire. My automotive knowledge and diagnosis is actually not bad, but my hands on is always a mistake, but you guys have made me so much better at it. Any advice where to check next? Not sure how to check the power going to coil. Any ideas would be greatly appreciated.
01V70XC05S60
01V70XC05S60 wrote: 20 May 2022, 13:37 Hi Gentlemen. You guys are awesome. You've helped me learn, and fix a lot. I have a 2005 S60T awd that has a cylinder 5 misfire. I've replaced MAF, air filter, all 5 coils and plugs. I can hear injector clicking, and I've swapped coils. I put in NGK iridium top grade plugs because I got them free. I also bought aftermarket coils because they swore they are better than the OEM, and modeled after the OEM, but replacing some of the weaker areas with higher quality material. My cheap scanner is only reading the #5 misfire. My automotive knowledge and diagnosis is actually not bad, but my hands on is always a mistake, but you guys have made me so much better at it. Any advice where to check next? Not sure how to check the power going to coil. Any ideas would be greatly appreciated.
