Subframe Bushing insert job
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Re: Subframe Bushing insert job
Post by azureblue »
Finally have time to get this done - I called Volvo to order the parts, and they told me the two rear bushings are different (illustration #'s 25 for right rear and 26 for left rear), plus what looks to be some sort of conical washer just for the right side. No mention of an O ring, but FCP shows a plastic washer
https://www.fcpeuro.com/products/volvo- ... o-31329447 - which looks like what Volvo shows in their parts illustration.
And FCP shows only one type of bushing...
Do I need to replace the metal subframe retaining washers?
While I'm not doubting the advice here, I want to get the right parts// I was going to order from FCP, BTW.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 262 times
Post by Blacklab467 »
I'm not sure what that white plastic washer would be for, The 2003 XC's didn't use that, I'll try to find it in the Volvo parts online though, you should get those if your year specifies that. The big washers come with the new bolts you will want to purchase for the job, they are about 8 bucks each.
Just to be clear......you are talking about replacing the subframe bushings (4) on the front subframe which cradles the engine right? Yes, the original driver's rear bushing that you remove will have an oblong hole as opposed to a round one, I'd be surprised if you can get an OEM replacement for that bushing, I have read on many forums that that oblong bushing is not actually available but I could be wrong. Standby...... I'm going to look into that part on the Volvo fiche.
2003 XC 70 (sold)
Blacklab467
OK, so on the 2001 V-70 microfiche it shows that plastic washer kit of 4 part number 31329447, I would get that. Items 25 and 26 reference the same part number 3507923 of which you need 4 of. Item 29 is the large washer, you can reuse your old ones. Item 30 is the engine cradle bolt which comes with the washer, get 4 of these. Strangely the diagram doesn't show the 2 front subframe bushings but I can assure you they are the same as the others, 3507923. Volvo does not show a separate part number for the originally installed oblong left rear subframe bushing that came with your car new.
Now go jack your car up securely and get a box of beer and wait till Saturday afternoon!
2003 XC 70 (sold)
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Somewhere on a Volvo engineering drawing written is very small Swedish is likely a brief note explaining poorly why some engineer or technician felt he could justify a change order and change the washer. Maybe.
vtl
Year and Model: 2005 XC70
Been thanked: 606 times
Post by vtl »
Blacklab467 wrote: 14 Apr 2022, 17:45 I'm not sure what that white plastic washer would be for, The 2003 XC's didn't use that
Means, someone took it out already.
Blacklab467
Yeah, that white plastic thing goes between the subframe bushing and the large washer, probably to prevent friction and squeaking. Not a bad idea really.
2003 XC 70 (sold)
azureblue
Post by azureblue »
Much thanks for the explanation and breakdown. Especially that white plastic part. I couldn't understand why the illustration showed 2 numbers for the rear bushings, either, when they referenced the same part. I know the bushings have to be turned a certain way when installing, so maybe that could have something to do with it.. I need to check with Euro to see if the bolt comes with the metal washer. Is there a better source? I am planning on ordered the Lefendorfer (sp?) Bushing.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Blacklab467
The bolt does come with the washer, in fact it cannot be removed from the washer. For the extra 8 bucks each purchase the Volvo brand bushings.
2003 XC 70 (sold)
azureblue
Post by azureblue »
Thanks - I was calling #29, the washer.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Blacklab467
I wouldn't bother replacing those.
2003 XC 70 (sold)
