weitau
Year and Model: 2004 V70
Has thanked: 7 times
Been thanked: 2 times
Post by weitau »
Skymongrel wrote: 30 Dec 2023, 16:30 2006 XC70 (190k), after replacing a noisy serpentine belt tensioner a couple weeks ago, I detected a new noise. It was a rhythmic humming noise that would go away if I turned the car one way to load and unload the front tires. I replaced my front left wheel bearing and noise is gone.
Doesn't it feel great to diagnose it and have the noise go away? :D
I've replaced nearly the entire front end, and I still have a clunking sound. The previous owner had severe damage to the shock assembly, and something else must be wrong.
2004 V70 2.4L
weitau
Post by weitau »
Very happy I didn't damage my engine from a low oil level condition a few weeks ago :)
These pics were taken 2 days ago, after driving mostly steady 60 mph on highway, Shell mid grade gas 89 octane, light breeze, Walmart 5W-30 high mileage synthetic oil, low load in car, 35psi tire pressure, Sailun Atrezzo tires, disconnected radiator fan.
2004 V70 2.4L, changed in the last year: DENSO 5304 Iridium Power plugs, Denso spark plug boot, rear wheel bearing, new pads and rotors, control arm bushings, Valvoline MaxLife ATF, Lucas Transmission Fix (saved tranny).
2004 V70 2.4L
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
Front control arms, ball joints, and wheel bearings/hubs on the 07 XC70. 170k miles, control arms and ball joints were replaced around 100k. Bushings were rough, ball joints were fine but did them any way so I don’t have to go back in there again later.
Took 3 hours for the first side, 2 for the second. Had to figure out how to pry the new arm down to pop the ball joint stud through and spline the cv axle at the same time :shock:. I used CTA 4019 to install the ball joints.
Originally ordered Beck Arnley for everything (RockAuto), since I’ve had good experience with them in the past (often reboxed OEM). But this time..wheel bearing was stamped PPS (ProParts Sweden) and the other parts were all Made in China. Ended up returning it all and going with Lemforder control arms and ball joints, and FAG wheel bearings/hubs.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I replaced the left control arm with a used control arm, while I wait out for volvo blue box bushings for the left control arm, I will replace them and then install it back. I should do the right side as well, however...they do cost a lot so I cannot to them at the same time.
Additionally I believe I need new shocks too but I am not sure what brand. I've heard mixed things about the Sachs brand(which is what I got according to the Volvo sticker on the shocks) since they moved production to Turkey.
Btw, someone tell me how they got the old droplinks out, considering the lower nut is pretty much obstructed by the subframe so I cannot use a ratchet.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Offset wrench. Or raise the transmission slightly.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
By drop links do you mean the stabilizer end links? If so, undo the top ones and then rotate (or pry) the stabilizer bar to get access to the bottom nut.
2003 XC 70 (sold)
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
dikidera wrote: 01 Jan 2024, 02:20 Additionally I believe I need new shocks too but I am not sure what brand. I've heard mixed things about the Sachs brand(which is what I got according to the Volvo sticker on the shocks) since they moved production to Turkey.
I’ve done two sets of loaded TRQ struts on an 08 S60 and 08 C70. The S60 is at 2 years and over 25k miles with them and they are still holding up. I put cheap Chinese ones on an 02 S60 and they should need replacing after 40k as while they don’t groan and squeak they ride a little harsh, wish I would have put TRQ on.
I believe I ended up using an offset box end wrench for my control arms. I tried a socket like the link below and didn’t work for me, YMMV.
DPTOOL Engine Motor Mount Socket 16mm 17mm 18mm 21mm 24mm
5pc Offset Wrench Kit
https://a.co/d/1nGWLjZ
08 C702.5T (sold)
The non-Swedes:
mtd240
Post by mtd240 »
dikidera wrote: 01 Jan 2024, 02:20 I replaced the left control arm with a used control arm, while I wait out for volvo blue box bushings for the left control arm, I will replace them and then install it back. I should do the right side as well, however...they do cost a lot so I cannot to them at the same time.
A Lemforder control arm is $90 at FCP - that can’t be much more than you’re paying for genuine Volvo bushings, and would save you a boatload of time installing/uninstalling, right?
Gone:
dikidera
Post by dikidera »
I am just looking for a more comfortable ride. Lemforder don't make nice rubber
Also the price of both bushings is the same for the bushings. And prolly 20 bucks to get them pressed in.
Blacklab467
Don't confuse Lemforder parts with Genuine Volvo.
2003 XC 70 (sold)
