Vida CEM swapping
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
I have seen many many cheap ones on ebay. But I figured that they might not be any good due too them maybe Causing unnecessary noise or reading packets incorrectly or not reading at all. , or not having standardised connection id's on the wiring harness.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
CEM cracking possibility was investigated using a $9.99 Saleae logic analyzer Chinese knock-off. It is $14.75 on ebay now. Later I decided to buy a genuine one, but they spoiled the software, so I went with DSLogic Plus, which is just awesome, both hw and sw. If $150 is a bearable sum for you, get the latter one.oscilloscope wrote: 13 Jun 2023, 14:56 Any suggestions ? , I was going to buy the addon for my scope but its typically back order.
oscilloscope
Yes that is much cheaper then the add on for my scope. That's 5 times the price of that.vtl wrote: 13 Jun 2023, 16:30CEM cracking possibility was investigated using a $9.99 Saleae logic analyzer Chinese knock-off. It is $14.75 on ebay now. Later I decided to buy a genuine one, but they spoiled the software, so I went with DSLogic Plus, which is just awesome, both hw and sw. If $150 is a bearable sum for you, get the latter one.oscilloscope wrote: 13 Jun 2023, 14:56 Any suggestions ? , I was going to buy the addon for my scope but its typically back order.
oscilloscope
i have managed too find a supplier over in the UK , it should be with me pretty soon i'll guessing.vtl wrote: 13 Jun 2023, 16:30CEM cracking possibility was investigated using a $9.99 Saleae logic analyzer Chinese knock-off. It is $14.75 on ebay now. Later I decided to buy a genuine one, but they spoiled the software, so I went with DSLogic Plus, which is just awesome, both hw and sw. If $150 is a bearable sum for you, get the latter one.oscilloscope wrote: 13 Jun 2023, 14:56 Any suggestions ? , I was going to buy the addon for my scope but its typically back order.
vtl
DSLogic?oscilloscope wrote: 16 Jun 2023, 14:12 i have managed too find a supplier over in the UK , it should be with me pretty soon i'll guessing.
oscilloscope
yes DSLogic Plus , 400mhz sampling rate & 256 onboard memory.vtl wrote: 16 Jun 2023, 14:16DSLogic?oscilloscope wrote: 16 Jun 2023, 14:12 i have managed too find a supplier over in the UK , it should be with me pretty soon i'll guessing.
oscilloscope
did you use any of the multi-com.pl break out boards & connectors or just the general wiring harness which i am assuming comes with the device?vtl wrote: 16 Jun 2023, 14:16DSLogic?oscilloscope wrote: 16 Jun 2023, 14:12 i have managed too find a supplier over in the UK , it should be with me pretty soon i'll guessing.
vtl
The ones with the board.oscilloscope wrote: 16 Jun 2023, 14:29 did you use any of the multi-com.pl break out boards & connectors or just the general wiring harness which i am assuming comes with the device?
- 9561 Views
Last post by RickHaleParker
- 9715 Views
- 27 Replies
- 30068 Views
Last post by cn90
- 11327 Views
Last post by jonesg
- 6432 Views
