Yes. Or blow away the chip with hot air and read it in a chip programmer.jeffbolem wrote: 10 Jul 2023, 09:27 Okay, so the only way to get the pin off of the brick cem is to read the flash memory directly off of the chip? Like the diagram Luke posted on pages 218-220?
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
oscilloscope
- Has thanked: 27 times
- Been thanked: 11 times
Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
jeffbolem
- Year and Model: 2004 v70R
- Has thanked: 1 time
I was just going to use a microcontroller and use Luke's code from page 218 to read the flash memory on the chip, since I already have a microcontroller. The usbjtag tool looks dope but I don't really have 500+ doll hairs to spend on that right nowoscilloscope wrote: 11 Jul 2023, 06:04 Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
Does the Chinese clone ELM327 support more custom commands? Its a nice tool when in a pinch but does not show etm throttle position.
In simpler terms, 7A A6 13 37 is for TPS1. The reason I am asking is because I have my suspicions that my Magnetti Marelli ETM might be in the initial stages of failure.
By driving with the little dongle I can at least verify if the tps1 and 2 diverge in any meaningful way.
UPDATE:Turns out TPS1 and TPS2 are not implemeneted on the Denso Bifuel ECU. I wonder what else I can use. The direct ETM commands don't seem to be documented.
oscilloscope
What? 500!! That's gone up considerably since last year!jeffbolem wrote: 11 Jul 2023, 21:08I was just going to use a microcontroller and use Luke's code from page 218 to read the flash memory on the chip, since I already have a microcontroller. The usbjtag tool looks dope but I don't really have 500+ doll hairs to spend on that right nowoscilloscope wrote: 11 Jul 2023, 06:04 Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
oscilloscope
I'm not sure which usbjtag you're looking at but I just checked on there site and it's $65jeffbolem wrote: 11 Jul 2023, 21:08I was just going to use a microcontroller and use Luke's code from page 218 to read the flash memory on the chip, since I already have a microcontroller. The usbjtag tool looks dope but I don't really have 500+ doll hairs to spend on that right nowoscilloscope wrote: 11 Jul 2023, 06:04 Its far easier and simpler too use usbjtag to connect too the back on the module instead of removing the flash chip considering its buried and annoying too get too. As far as I know the usbjtag tool is cheap for what it can do.
vtl
$65 is a lot of beer!oscilloscope wrote: 12 Jul 2023, 09:17 I'm not sure which usbjtag you're looking at but I just checked on there site and it's $65
oscilloscope
Yes very true I have a number of them floating aroundvtl wrote: 12 Jul 2023, 09:57$65 is a lot of beer!oscilloscope wrote: 12 Jul 2023, 09:17 I'm not sure which usbjtag you're looking at but I just checked on there site and it's $65Arduino is like $5, and it's a great chance you have one laying around.
jeffbolem
Jeez, maybe I was looking at the wrong one! That sounds like a much more reasonable price. Im using the Seeed Studio XIAO, which is like 20 bucks for three. They're pretty powerful for their size.oscilloscope wrote: 12 Jul 2023, 09:17
- 9622 Views
Last post by RickHaleParker
- 9809 Views
- 27 Replies
- 30365 Views
Last post by cn90
- 11448 Views
Last post by jonesg
- 6531 Views
