spinard
Year and Model: '04 V70R, '16 XC70
Has thanked: 1 time
Been thanked: 3 times
Post by spinard »
Looked at that messy seeping power steering fluid reservoir for the umpteenth time, and said "we should replace that"...for the umpteenth time.
Has thanked: 1611 times
Been thanked: 4072 times
spinard wrote: 27 Jan 2024, 14:55 Looked at that messy seeping power steering fluid reservoir for the umpteenth time, and said "we should replace that"...for the umpteenth time.
Soon you graduate to buying the part, putting it in the shelf, and doing the same.
:D
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
jonesg wrote: 29 Nov 2023, 15:54 kerosine/diesel heater for the garage, it uses a 12v battery for the combustion and fan, really puts good heat out.
normally i don't touch the volvo until winter is over, 5 months from now.
it sounds like a turbine jet spooling up.
highly recommend for freezing garages, $99 amazon.
I've watched a few Youtube videos on these things. I'm considering one for next year.... too cold to install one now, and the garage isn't clean enough any way.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
br0dy519 wrote: 26 Jan 2024, 20:06
jonesg wrote: 18 Jan 2024, 10:49 Bought flex pipe for exh downpipe.
Correct fit? I watched what seemed like 3 orangex videos totalling about 3 hours regarding that job and learned nothing.
i watched those same videos too, measured my pipe at 2 3/8th, so I bought 2 1/2 " ,
it doesn't matter if it doesn't slip fit as I'm welding it in.
the ends on the flex pipe are softer aluminized steel, unlike the stock volvo pipe its very easy to expand with pliers.
jonesg
Post by jonesg »
Krons wrote: 27 Jan 2024, 05:40 Got oil report back from Blackstone Labs. Overall great for an engine with 164k miles, first sample I’ve pulled on this car. Yet to do coils, fuel level would seem to indicate they may help fuel economy.
that looks very similar to my recent blood test.
jonesg
Post by jonesg »
454cid wrote: 28 Jan 2024, 18:01
my installation, cut a hole in the wall with a drill and sawzall , push the exh pipe through it.
jonesg
Post by jonesg »
BlackBart wrote: 21 Jan 2024, 09:34 One of the two big electrical connectors to the armrest controls was not coming out, and I was not about to force it.
i rotate the door panel so its upside down, its much easier to unplug the door connectors when you can see them.
once i started to break the blue slider blocks they kept breaking because the actuator arms were bent..
a new actuator was around $60, swap the motor into the new one to save money, you just need 4 large steel rivets.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Dorman makes decent actuator arm replacements, with and without motors. You can also use short bolts to replace the rivets and make the next change easier.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Interesting - the arms could be bent. Hmm.. They are pretty flexible sheet metal.
BlackBart
Post by BlackBart »
abscate wrote: 28 Jan 2024, 04:53 Soon you graduate to buying the part, putting it in the shelf, and doing the same.
The evolution of this pattern of behavior is buy the part, put in on the shelf, forget you have the part, buy the part again....
