RickHaleParker
Been thanked: 981 times
Post by RickHaleParker »
abscate wrote: 20 Mar 2020, 15:55
Man, you can lead a horse to the internet, but you can’t make him link ..
viewtopic.php?f=1&t=88623
Leading and ending brackets removed to show format.
Format: url=URL]Text[/url
Example:
Solved the mystery of Evita's interior lights funkiness!!!
url=viewtopic.php?f=1&t=88623]Solved the mystery of Evita's interior lights funkiness!!! [/url
Active
Past
Has thanked: 1614 times
Been thanked: 4078 times
Knocked apart the entire 1998 HVAC system and got a real nice evaporators for my troubles, and a bunch of good MCC parts
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
abscate wrote: 20 Mar 2020, 15:10
Stu70 wrote: 20 Mar 2020, 13:27 .... and .... it was theeeee...?
You will have to read the thread - only the Tease here...
viewtopic.php?f=1&t=91400&p=536680#p536680
There, I fixed it for you
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
abscate wrote: 21 Mar 2020, 17:04 Knocked apart the entire 1998 HVAC system and got a real nice evaporators for my troubles, and a bunch of good MCC parts
Very nice! Do you know the lifespan of an evaporator? When I do my AC I'm trying to figure out what else could/should be replaced.
07 V50 T5 AWD M66 ~146k miles
First one on my 1999, 6 years then leaked
Nissans replacement now 7 year old, no leaks
No leaks defined as AC charge has lasted 7 years, no top-ups and good 40 F delta performance
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
abscate, did you do photo documentation of the HVAC removal process?
I did some back in 2013 when I was a MVS NooB
There are good DIY in pdf form
abscate wrote: 07 Nov 2016, 10:11 Changed my oil on a beautiful 55F fall day, new Mahle filter, Mobil 1.
Got on my knees and thanked my 1999T5 for still running me around reliably at 180k miles with two last kids in college. Two more years
Got back on my knees and thanked for the 2 years, and the additional two years past that.
Got to use the bump function to bump the AC oring thread for dirk
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
Since I am stuck at home for the last and next week, I have been doing some work to my 98 V70. I repaired the leaking trans cooler lines, by cutting off the crimps, installing new hoses and o-rings. Rebuilt a spare headlight motor from an 850 to work in my V70 on the drivers side, now it doesn't stop wherever it wants. I installed side marker lights and my 16" summer tires and rims, installed my 2000 V70R dual exhaust (needs new tips). I then went to cleaning the interior, I tried a method I read about here using a magic eraser. I used windex and went through 4 magic erasers and it sure makes a difference, took a pic of the panel above the rear hatch one side clean, the other dirty. I also cleaned and conditioned my seats with Auto Glym leather cleaner and conditioner. Currently trying to tint my rear windows, I attempted it a few months back, got frustrated and gave up, but I have more time to kill now. Since most forums like pictures:
Dual Exhaust:
https://drive.google.com/open?id=1LCdG4 ... OQo119AUnc
Wheels and markers:
https://drive.google.com/open?id=1LCVW1 ... UrBdQB6QNz
During Cleaning:
https://drive.google.com/open?id=1LEhyy ... fAatLGP6M3
After Cleaning:
https://drive.google.com/open?id=1LD5Q9 ... fB_oVdKu_j
https://drive.google.com/open?id=1LDFw4 ... aBIwCX89bG
https://drive.google.com/open?id=1LDQ9a ... GfRDe-1_1E
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
The interior looks really nice! Well done!
Spent the last few hours trying to pull the driver side axle from the S60... not going so well. I went and rented a slide hammer and axle puller attachment from O'Reilly, but that's not quite doing the trick. I thought the one I had in my R was seized... this one is horrible! I can get pry bars and whatnot between the axle and transmission, but I can't get the thing to budge.
I'll get back at it tomorrow... hopefully the PB blaster will do something to loosen it up. At least I'm able to work on the car in the garage now that my dad's X3 is running with its new engine!
