Do it yourself ABS module repair. Topic is solved
This topic is in the MVS Volvo Repair Database » Do It Yourself ABS Module Repair
wysiwyg
Year and Model: 1997
Re: Do it yourself ABS module repair.
Post by wysiwyg »
Yeah and im checking between the pin and the circuit board track its supposed to connect to.. so if i get a signal it cant be broken..or am i missing something. New to this.
Cheers
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Just resolder the small pins. It's already open and takes a few minutes.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
xtrattitude4u
Year and Model: 1998 S70 2.4l N/A
Post by xtrattitude4u »
I've been through three units and I still get the same symptoms.
The lights will go out immediately after start up, but will come back on during hard acceleration or in any situation the traction control would be needed. The abs works, so long as the lights are still off. I swapped out a speed sensor, cleaned all of them. Checked all wires, Even replaced the main wiring connector. The entire front suspension plus an Axle are brand new.
Any ideas?
elchopperfreak
Year and Model: S70 T5 1999
Post by elchopperfreak »
Anything on the up to 04 S40/V40 ? Anyone has pics??
How abut the DSA module??
Thanks
Peteh1
Year and Model: v70,1998 1995 850, 2
Post by Peteh1 »
just did my 2000 v70 xc, it took about 1 hour to do the whole job, started the car and all tracs and abs lights flickered for a millisecond and went out, took the car for a 35 mile ride and everything worked great, tomorrow I'll do my 1998 v70 wagon....the article is GREAT, please keep em coming the economy is terrible and people like you and sites like this one, help us all out, and keep us up and running....THANKS AGAIN GREAT JOB........Pete
woodchopper
Year and Model: 2010 S80 T6 AWD
Post by woodchopper »
Many thanks to everyone for all the work and pictures you have contributed. My ABS light was coming on infrequently. I took it off and apart. I could not see any cracks in the solder using a magnifying glass so I decided to just put it back on without doing anything to it. I sprayed the connectors and the metal tubes that the module slides onto(electrical contact cleaner). The light has not come on yet but it has only been a day or so. Makes me wonder if it was just the connectors needing to be cleaned. So I just wanted to suggest that anyone with the ABS light coming on try spray cleaning the connectors before going to all the work of tearing the module apart.
This is on a front wheel drive non turbo. I don't know anything about the tracs issue.
aisrael
Year and Model: 1993 244 1995 854
Post by aisrael »
My 99 V70 NA has the Tracs, abs, check engine, and brake lights are on witb speedometer not working. I am 99% sure it is tbe module. Has anyone used Midwest ABS before
Is the repair difficult to fix myself?
Aaron
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
MidWest ABS is Matty-Moo from this site and can be 100% trusted. Good work at a fair price. Don't hesitate.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
woodchopper wrote:Many thanks to everyone for all the work and pictures you have contributed. My ABS light was coming on infrequently. I took it off and apart. I could not see any cracks in the solder using a magnifying glass so I decided to just put it back on without doing anything to it. I sprayed the connectors and the metal tubes that the module slides onto(electrical contact cleaner). The light has not come on yet but it has only been a day or so. Makes me wonder if it was just the connectors needing to be cleaned. So I just wanted to suggest that anyone with the ABS light coming on try spray cleaning the connectors before going to all the work of tearing the module apart.
By disturbing the board and moving it and putting pressure on it you've temporarily alleviated the symptoms by closing the cracks in the board; but the symptoms will be back
richeros
Year and Model: XC90, 2005
Post by richeros »
Hi everyone and thank you Lee for this post.
I registered here just to say that I took a chance on my 2005 XC90 and went ahead with this fix.
All the symptoms where there and Volvo estimated me 2200$ for a new unit.
And guess what it worked out just fine. The ABS light was still on after the fix but just like described here it turned itself off after a minute or two of driving.
Ive been around a lot after the fix and everything works just fine.
Thank you guys and of course Lee!
Richard
