OK
Vida CEM swapping
ricked
- Year and Model: xc90
- Has thanked: 6 times
- Been thanked: 2 times
sorry to dig up this old post but i have indeed the p3 cem like in picture and scrip cant find the part number and stopsvtl wrote: 17 Dec 2021, 13:15It's in VIDA, in information section, under cables and fuses.RickHaleParker wrote: 17 Dec 2021, 02:06P3 on the bench .. Follow this link and get a EWD ( Electrical Wiring Diagram ). See if you can figure it out.eltoro wrote: 16 Dec 2021, 13:58 Does anyone have some instructions about the P3 bench setup? It would be a great way to start playing with the code and setup?
the question is what is "Teensy loaded with VTL's P3 branch. Do not use the Main branch" there is no P3 in the script or on github
also this type uses 10 digit pin code not 12
edit:
i think i found it but script still dont have P3 in it and pin code is 6 bites instead of 5
this cem is with a R32C processors R5F64524 with pin in d-flash at 0x0
problem is that i found now 3 difference pcb's but the one i have i can not read eee, Dflash and flash to extract pin from Dflash
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
ricked wrote: 11 Feb 2024, 04:22 sorry to dig up this old post but i have indeed the p3 cem like in picture and scrip cant find the part number and stops
vtl
Use the p3 branch: https://raw.githubusercontent.com/vtl/v ... racker.inoricked wrote: 11 Feb 2024, 07:21 thanks vtl but this script extracts pin code is 6 bites instead of 5, i did not try it yet but does it work you think, also i did edit the above post just before your reply
ricked
thanks, i will try it tomorrow and post resultsvtl wrote: 11 Feb 2024, 07:27Use the p3 branch: https://raw.githubusercontent.com/vtl/v ... racker.inoricked wrote: 11 Feb 2024, 07:21 thanks vtl but this script extracts pin code is 6 bites instead of 5, i did not try it yet but does it work you think, also i did edit the above post just before your reply
vtl
00 00 bb e2 b0 is your PIN code. If your software can't accept HEX numbers you can feed it any DEC pin generated by utils/seed-gen. To give you a few:ricked wrote: 12 Feb 2024, 15:55 well i did try but after 2x 5 hours i get "hash collision found" both times
any suggestions?
Code: Select all
$ ./seed-gen --seed "a5 39 17" --key "da b5 46"
Searching all hash collisions for SEED a5 39 17, KEY da b5 46 at 866 tries per second
8.07 hrs [ 1] PIN 00 25 15 71 83
8.91 hrs [ 2] PIN 00 27 77 87 35
11.26 hrs [ 3] PIN 00 35 10 63 91
12.10 hrs [ 4] PIN 00 37 72 95 27
14.94 hrs [ 5] PIN 00 46 58 90 02
15.67 hrs [ 6] PIN 00 48 85 33 61
18.86 hrs [ 7] PIN 00 58 80 21 73
20.63 hrs [ 8] PIN 00 64 30 42 90
23.85 hrs [ 9] PIN 00 74 35 50 82
25.96 hrs [ 10] PIN 00 80 93 72 20
28.08 hrs [ 11] PIN 00 87 55 33 81
29.18 hrs [ 12] PIN 00 90 96 60 32
31.27 hrs [ 13] PIN 00 97 50 21 93
36.24 hrs [ 14] PIN 01 12 99 10 79
40.84 hrs [ 15] PIN 01 27 32 91 58
65.31 hrs [ 16] PIN 02 03 62 43 87
68.54 hrs [ 17] PIN 02 13 67 51 95
77.06 hrs [ 18] PIN 02 40 25 86 22
77.78 hrs [ 19] PIN 02 42 47 70 94
78.85 hrs [ 20] PIN 02 45 81 31 35
80.26 hrs [ 21] PIN 02 50 20 94 30
80.97 hrs [ 22] PIN 02 52 42 62 86
82.06 hrs [ 23] PIN 02 55 84 23 27
106.55 hrs [ 24] PIN 03 32 19 18 87
^C
ricked
"00 00 bb e2 b0" is pincode after that sorry to say i have realy no clue what your talking about..
and indeed i need a 10 digit pin to give in the software
also feed to what, is there a other calc/ script to use to decrypt "00 00 bb e2 b0" ?
i did think that there was a real pincode like in the P1/P2 script not a HEX feedback that also needs to be decrypted
please point me in the right direction to decode this HEX "00 00 bb e2 b0"
thanks
thanks
rkam
- Year and Model: 14473_96090_XC7007
- Has thanked: 5 times
- Been thanked: 25 times
P3 doesn't use a visible PIN code sent over CAN bus like the older ones.
First the controller sends a random seed number to you
Then your software uses a pin code and a calculation algorithm to calculate a key for that specific seed number.
Next your software sends that key back to the controller.
The controller will then do the same with its built in pin code and algorithm, and check that your key matches.
There are 65536 different pin codes that will give the correct key. The cracker is using the first one that starts with 00 00.
One of them is stored in your controller, but the cracker doesn't know which one, and it doesn't really matter.
If your software can send pin codes in HEX numbers, then you can used the pin found by the cracker.
But if your software require a pin code with only numbers 0-9, then you need to find a pin code with just numbers.
VTL points you to a tool that can take a matching pair of seed and key, and calculate different working pin codes with just numbers.
He has also already calculated 24 different working pin codes for you with that tool, based on your matching pair of seed and key.
Note:
The explanation of hex and numbers above is not fully correct.
If the cracker finds a pin code including a number like BB in hex. That is 187 in decimal numbers.
A pin code with numbers like 77 is also a hex number, but it contains only 0-9 and not 0-F. 77 in hex is 119 in decimal.
HEX is practial because a byte (0-255) can be written as two digits/letters (00-FF)
Note:
- 9659 Views
Last post by RickHaleParker
- 9864 Views
- 27 Replies
- 30511 Views
Last post by cn90
- 11524 Views
Last post by jonesg
- 6598 Views
