How did you read them? IIRC Renesas erases the flash when the read operation is attempted on a locked down flash.rkam wrote: 17 Feb 2024, 14:22 The ones I've checked have flashing pin codes set.
Two had the same pin, and one had +1 on all bytes.
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
vitalik2134
- Year and Model: Volvo XC90 2006
- Has thanked: 1 time
If anyone is interested, here is a flash DICE@000000 read by orange5 for experiments
- DICE flash 000000.rar
- (62.04 KiB) Downloaded 152 times
vtl
It has no flash pin code, so it can be read in boot mode.vitalik2134 wrote: 19 Feb 2024, 08:56 If anyone is interested, here is a flash DICE@000000 read by orange5 for experiments
Kravi80
- Year and Model: S60 my09
- Has thanked: 2 times
- Been thanked: 2 times
http://www.ddmauto.ru/programmatoryi/st ... c-m30855fwSkavac wrote: 02 Feb 2024, 22:02 Anyone knows if CEM-L can be read with Orange5? I can see it supports M30855F, but I can't find a wiring diagram to connect the CEM to the orange 5. Reason I am asking because failed write with IOTerminal. Now CEM is dead
Clk, busy, p50, p60 no need to be connected in M32C UART mode (in M32C SPI must be connected).
Chips adm... and 93c86 must be desoldered.
WhizzMan
- Year and Model: 2001 XC70
No. You need to remove it from the car and directly read the content on the bench and find the PIN in there. There is no known vulnerability in these that will make it doable to find the PIN in a reasonable time.MrP wrote: 26 Feb 2024, 04:45 Hi guys I was wondering if the "brick" cem is possible to Crack yet? I read you need to keep the k line active but I haven't seen it being cracked yet and I read a lot. Through the posts.
- 9912 Views
Last post by RickHaleParker
- 10278 Views
- 27 Replies
- 31574 Views
Last post by cn90
- 12111 Views
Last post by jonesg
- 7048 Views
