smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Ocelot wrote: 16 Jul 2020, 07:49 How do you even replace that engine mount? Is there a how-to available on the MVS website?
I washed my car today and gave it a good polish. See the results below :D
The clear coat is damaged on the hood. There's also a little rust spot. Anyone with a good tip/how-to to fix that? Or is it easier to find a used hood in the same color?
Bonus pic made by my girlfriend including yours truly :)
FCP Euro has a video of replacing the front and rear mounts on an 850. You have to jack up the engine by the oilpan, but it's pretty tough because the new ones will likely be taller than the old ones. There's also some notes about not jacking it too high or you could damage a CV axle, which I think is what I did.
07 V50 T5 AWD M66 ~146k miles
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Does anyone know what size hex is needed to remove the bolts for the AC lines? The T40 is too small and the T45 is too large. I've never seen an in between size.
subzerocarfanatic
Year and Model: 2000 Volvo C70 HT
Has thanked: 75 times
Been thanked: 10 times
Post by subzerocarfanatic »
Removing from the inside frame rail or just to replace or what? I just removed mine to wrap with cork insulation.
subzerocarfanatic
ZionXIX wrote: 16 Jul 2020, 09:24 Does anyone know what size hex is needed to remove the bolts for the AC lines? The T40 is too small and the T45 is too large. I've never seen an in between size.
You sure it not full of gunk or something because a T40 worked on my P80 on both hex bolts where it bolts to the top side, the 2 side by side.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
I think they're hex, not torx. I wanna say they're 7 or 8mm.
subzerocarfanatic
bmdubya1198 wrote: 16 Jul 2020, 09:36
I guess I just got lucky. lol
Has thanked: 1613 times
Been thanked: 4077 times
It’s an H6 for both the hard line and the mount.
You want a nice sharp bit, flood it with Pb blaster , get the hex bit engaged and then give it a couple of sharp raps with a hammer.
H6 is 6 mm six point hex bit
ZionXIX
Post by ZionXIX »
I guess I get to buy a hex socket set.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
ZionXIX wrote: 16 Jul 2020, 11:00 I guess I get to buy a hex socket set.
great then you can start replacing brake pads too!
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Nice ride man! Love those T5 wheels too.
Is that hitch model removable? If not maybe you can splash some paint on it, looks a bit crusty.
BMW 540i 2002
S70 Base 2000
