Has thanked: 1613 times
Been thanked: 4078 times
I don’t Know. The T4 suddenly felt slow and when I looked back an S70 was attached
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Yeah, that happens sometimes when I drive my mom's XC90.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Ok Abscate, karma found me. The lower passenger side compressor bolt is place perfectly to avoid all combinations of sockets and extensions. I can get good access through the wheel but it's going to require a swivel joint and my impact. I really thought the compressor was coming out tonight. Oh well, maybe tomorrow will be the day.
The 1999 is much worse. Just when you think you have it out the socket hits the radiator for the last1/2 inch on all four bolts ( they go fore aft on the 99)
You need a 12 mm ratcheting box end or it is hell.
Clean those bolts to newness and chase the threads while the compressor is out and life is much better
ZionXIX
Post by ZionXIX »
abscate wrote: 18 Jul 2020, 04:33 The 1999 is much worse. Just when you think you have it out the socket hits the radiator for the last1/2 inch on all four bolts ( they go fore aft on the 99)
I would have preferred that since I pulled the radiator to do this job.
ZionXIX
Post by ZionXIX »
Got the compressor out finally. Impact swivel removed that lower bolt before I realized I pulled the trigger. Turns out removing the upper bolt first is ideal due to the weight of the compressor impinging the upper bolt if it's the last one to be removed. Pulley spins really well but is making some scraping noise and is definitely the wierd sound I've been listening to for years, literally the last decade. Went away as sound as I bypassed the AC with a shorter belt.
Next order of business was the dryer with its wonderfully non functional "quick" disconnect. Took an hour to get it apart. First I tried the normal way with a plastic disconnect tool. During all of the struggling and cursing there was a familiar voice in the background...
"just cut the line and deal with it later"...
That's a terrible idea
"Just Cut It"
I'm not doing it, I dont even have a sawzall anyway
"CUT IT"
I do have a dremel though...
*Spoiler* I cut the line
Used a crescent wrench and an impact to remove the remaining piece from the line.
When you are getting a new drier this takes an hour of Hades into five minutes of Dremel
I’m bookmarkingthat trick to dig the last piece out of the soft hose, though, nice.
ZionXIX
Post by ZionXIX »
abscate wrote: 18 Jul 2020, 16:53 When you are getting a new drier this takes an hour of Hades into five minutes of Dremel
I already have the drier
ZionXIX
Post by ZionXIX »
When reassembling the drier and AC line should I use teflon tape on the threads or a little antisieze?
bmdubya1198
ZionXIX wrote: 19 Jul 2020, 07:17 When reassembling the drier and AC line should I use teflon tape on the threads or a little antisieze?
I would probably dab a little anti-seize on it. I don't think the teflon tape should be necessary.
