Vida CEM swapping
- repair
- Year and Model: S60 II 2015
- Has thanked: 2 times
- Been thanked: 3 times
On S60 - yes, but only up to 10 years, with a different CEM design.
Volvo S40, V40, V50, V60, S60, S80, V70, XC60, XC70, XC90, C30, C70 - Р1, Р2, Р3, 1998 - 2016 - language replacement DIM, ICM, PHM.
solitaire
- Year and Model: v40 2016
- Has thanked: 3 times
- Been thanked: 6 times
to vtl
cracker always finds first two correct, on some version 3td is wrong
maybe it's possible modify code:
if cracking PIN code fail, brute force with first two and 3td use next closest candidate
if you understand what I mean.
blasaab
- Year and Model: Volvo xc90/V50/144
I can open the gerber file off pcb but cant insert it on page like https://www.seeedstudio.com/fusion_pcb.html for manufaction?. do you have more info on the other parts on that board. maybe links for software if you want to share that infosolitaire wrote: 21 Mar 2021, 09:33RickHaleParker wrote: 20 Mar 2021, 12:13 Are you going to contribute a Gerber file to the project?
What chips did you use?
Looks like you are drawing power from Vusb. In the current schematic that is listed as an unknown. Can you confirm Vusb has significant power to run the assembly?
for CAN I use max3051 (3.3V), powered direct from teensy (max 250mA), https://www.pjrc.com/teensy/card10a_rev2_web.pdf
max3051 maximum current 70mA x 2 = 140mA (https://datasheets.maximintegrated.com/ ... AX3051.pdf)
gerber and box for 3D attached
- RickHaleParker
- Been thanked: 980 times
I had to translate the Russian part of the files name to English before I could load and render on one of the websites ... Unrecognised character error.blasaab wrote: 24 Mar 2021, 13:49 I can open the gerber file off pcb but cant insert it on page like https://www.seeedstudio.com/fusion_pcb.html for manufaction?. do you have more info on the other parts on that board. maybe links for software if you want to share that info
Active
Past
Past
- RickHaleParker
Looking ahead in hope of finalizing my hardware.
Reference: Tennsy 4.0
Q1. Is the K-line going to go on CTX3/CRX3 ( Pads 30 & 31 0n the back ) or CTX4/CRX4 pins 11 & 13?
( I am assuming PJRC misprinted the pinout CTX4/CRX4 as a second set of CTX1/CRX1 for the FlexCAN libary information).
Q2. Third CAN Bus transciver needed for the K-Line?
A1 ____________________
A2 ____________________
Active
Past
Past
- 9536 Views
Last post by RickHaleParker
- 9676 Views
- 27 Replies
- 29942 Views
Last post by cn90
- 11275 Views
Last post by jonesg
- 6376 Views
