The one I have with 30855 is also 0 in the key bytes, the one with 30835 is the damaged one from the car I was trying to salvage, this one however states it needs a password to read in JTAG.
I will try USB to serial on the 30835, maybe it works.
Vida CEM swapping
porcupine7655
- Year and Model: 2006
- Been thanked: 20 times
I think it is good to do it on a controlled way to show in what stage it fails.oeben wrote: 29 Jun 2025, 11:18 The one I have with 30855 is also 0 in the key bytes, the one with 30835 is the damaged one from the car I was trying to salvage, this one however states it needs a password to read in JTAG.
If you get any readable string from version command, such as VER.1.16, you know that your wiring is correct. To be sure, test several times or even better in a loop. It can still be so that the cpu restart of any reason at some point after.
After the login is sent, it can be seen in the status bits if it is OK or not. Don't remember what bits to look for. In my example I print out status several times, before and after login.
In this way we can see what the problem is.
I'm also somewhat confused what interface was used when you say JTAG. As far as I have been able to find out there is no debug interface on this chip. How was this JTAG interface connected? What pins was used?
I was mistaken, I thought it was JTAG but it's SPI.
That's why it will not read without the PIN, it would be possible to retreive the PIN if it was communicating (in car with the equipment I have available).
I will have to look into it deeper next week, I tried repairing the PCB by fixing burnt traces and cleaning all corrosion, but still no comms.
Will try with the program you attached to see what happens.
oscilloscope
- Year and Model: 2005
- Has thanked: 27 times
- Been thanked: 11 times
I have been looking for a complete wiring diag for a late 2010 v50 for a sid807evo and the p2 cem so I can do some bench testing for synchronisation procedures over obd, or obtaining the eeprom & flash from the sid807, I found this site (below) and got a strange feeling it was to good to be true has anyone tried viewing the pdfs for the wiring diags ? As they do not open within the browser you have to click the pdf button which I have not done.
https://volvodiag.com/ewd-online-eng/
EDIT :
never mind it looks like it was loading differently on my mobile compared too when i loaded it on my laptop that site above looks like a genuine volvo site.
EDIT :
Treur
- Year and Model: 2007 V70
- Has thanked: 3 times
- Been thanked: 7 times
Anyone can help with eeprom decode algo? Two days, and 61bytes decrypted at all......
Code: Select all
#!/usr/bin/env python3
def hex_to_bytes(hex_string):
return bytes.fromhex(hex_string.replace(" ", ""))
KEY = "96 BB 1D 13 B3 07 D2 39 FC 20 26 D8 30 8D 31 3F 4B EB 3C D4 2E C3 76 5D 20 BC 31 81 77 19 EF 3E 27 0C 69 7E 1B 1C 15 AE 66 BE 1F 56 3B B1 F4 6C DC 98 9B 18 74 E8 44 EA 7F F4 AE 6A 25"
key_bytes = hex_to_bytes(KEY)
def get_subtract_value(group):
if group == 0:
return 0
elif group == 1:
return 1
elif group == 2:
return 2
elif group == 3:
return 3
elif group == 4:
return 4
elif group == 5:
return 5
else:
return group
def decrypt_file(input_file, output_file, key_bytes):
key_len = len(key_bytes)
with open(input_file, 'rb') as f:
encrypted_bytes = f.read()
decrypted_bytes = bytearray()
with open('decrypt_log.txt', 'w') as log:
for i in range(len(encrypted_bytes)):
group = i // 61
key_index = i % key_len
subtract = get_subtract_value(group)
temp_byte = encrypted_bytes[i] ^ key_bytes[key_index]
decrypted_byte = (temp_byte - subtract) & 0xFF
decrypted_bytes.append(decrypted_byte)
log.write(f'Byte {i:4d} (group {group:2d}): {encrypted_bytes[i]:02X} ^ {key_bytes[key_index]:02X} = {temp_byte:02X} - {subtract} = {decrypted_byte:02X}\n')
with open(output_file, 'wb') as f:
f.write(decrypted_bytes)
if __name__ == "__main__":
input_file = "crypted.bin"
output_file = "decrypted.bin"
decrypt_file(input_file, output_file, key_bytes) -
WhizzMan
- Year and Model: 2001 XC70
- Been thanked: 2 times
Not enough information.
What device are you trying to decypher? Please provide all binaries you have. How did you get a 61 byte key? What cypher is being used? It doesn't make sense you have a 61 byte key, it's just an odd number.
If the binary you are trying to decypher is more than 61 bytes, you need to loop over it somehow, if the key is only 61 bytes. This is why it is important to know what cypher is being used.
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
If you are trying to decrypt CEM L eeprom i have solutionTreur wrote: 09 Jul 2025, 10:35 Anyone can help with eeprom decode algo? Two days, and 61bytes decrypted at all......Code: Select all
#!/usr/bin/env python3 def hex_to_bytes(hex_string): return bytes.fromhex(hex_string.replace(" ", "")) KEY = "96 BB 1D 13 B3 07 D2 39 FC 20 26 D8 30 8D 31 3F 4B EB 3C D4 2E C3 76 5D 20 BC 31 81 77 19 EF 3E 27 0C 69 7E 1B 1C 15 AE 66 BE 1F 56 3B B1 F4 6C DC 98 9B 18 74 E8 44 EA 7F F4 AE 6A 25" key_bytes = hex_to_bytes(KEY) def get_subtract_value(group): if group == 0: return 0 elif group == 1: return 1 elif group == 2: return 2 elif group == 3: return 3 elif group == 4: return 4 elif group == 5: return 5 else: return group def decrypt_file(input_file, output_file, key_bytes): key_len = len(key_bytes) with open(input_file, 'rb') as f: encrypted_bytes = f.read() decrypted_bytes = bytearray() with open('decrypt_log.txt', 'w') as log: for i in range(len(encrypted_bytes)): group = i // 61 key_index = i % key_len subtract = get_subtract_value(group) temp_byte = encrypted_bytes[i] ^ key_bytes[key_index] decrypted_byte = (temp_byte - subtract) & 0xFF decrypted_bytes.append(decrypted_byte) log.write(f'Byte {i:4d} (group {group:2d}): {encrypted_bytes[i]:02X} ^ {key_bytes[key_index]:02X} = {temp_byte:02X} - {subtract} = {decrypted_byte:02X}\n') with open(output_file, 'wb') as f: f.write(decrypted_bytes) if __name__ == "__main__": input_file = "crypted.bin" output_file = "decrypted.bin" decrypt_file(input_file, output_file, key_bytes)
- 9561 Views
Last post by RickHaleParker
- 9715 Views
- 27 Replies
- 30068 Views
Last post by cn90
- 11327 Views
Last post by jonesg
- 6432 Views
