Oh yes ok you gave me an idea, i can use the Dremel and a cutoff wheel, that would do a nice clean job without worry about ruining the pipe. Just have to get the length right.454cid wrote: ↑29 Jan 2023, 23:13The source is the vacuum tree on the the intake manifold. I think all ports are the same.
I put a gauge on my car, and it was in the teens (psi) at idle. I just googled for a generic spec for any/all engines and it was in the ball park.I also dont know if my car produces enough vacuum to operate it properly yet.
It might work. If the hose is too flexible (and it doesn't sound like it) I'd go with some sort of tin snips. Maybe even a utility knife would work. Maybe try a couple of cuts in the area you know you'll need to be cut off, and see what works best?I also ran into another little problem. The metal hose i purchased is too long, way too long, to fit the car. It has to be cut down by at least 12 inches probably more. I guess this is cut with a hacksaw? It appears to be made of aluminum. The metal is rather thin, but it seems to be sturdy unlike the old piece of junk that was on there before. It did fit on the exhaust manifold pipe nice tight fit.
I got the ports capped off now as per other ideas from members. It runs pretty nice like that maybe i should not mess with it now ha ha.
