Wagon shakes when I apply break, vibrations that rattle cab Topic is solved
mabbott31
A common problem is that the caliper pins freeze and won't allow the brake pad to retract. This causing heat build up on the rotor which causes it to warp. Take a look at the pads to see if they are wearing evenly on both sides of the rotor. You may want to replace the caliper as well when the time comes.
- 18 Replies
- 2094 Views
Last post by tom4342
- 2805 Views
Last post by MadeInJapan
