Got me a big squeezy tube of anaerobic sealant and a foam roller to reinstall the top half of my cylinder head. One thing that is not consistent in all the instructions I've read on the intertubes: should one apply the sealant to both surfaces that will be in contact, just the top half, just the bottom half, ?????
My inclination is to put sealant on the top half and leave the bottom half clean, where I will install the spark plug seal o-rings. I suspect the surfaces are clean and flat enough that it doesn't matter either way, but if anyone with experience can chime in, that'd be appreciated.
Cam cover - on which surface to apply sealant? Topic is solved
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Bottom surface but make sure that you install it in 15 minutes after the sealant is applied.After that it isn't usable anymore.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I always apply the sealant to the cover. It is anaerobic so there is no rush to install the cover. It will NOT dry as long as air is on it. Two hours, 6 hours, 48 hours, doesn't matter as long as it is kept clean. I usually don't apply to much, don't want it clogging the small oil passages. Apply it like a thick coat of paint. The cover almost seals itself, the sealant just seals the deal.
One of those 1.69 oz tubes will do 2 or 3 covers.
How so? The anaerobic stuff will never set to dry until both surfaces are tightened down.misha wrote:Bottom surface but make sure that you install it in 15 minutes after the sealant is applied.After that it isn't usable anymore.
ugh smh 850 Turbo fridge
- rspi
Contact rspi..
Start at 15:15
- Been thanked: 504 times
@rspi, you need to add a prefix "an" to that word. It should be anaerobic.rspi wrote:..It is aerobic so there is no rush to install the cover...
- misha
Don't know....that's what i was told at "stealership" a long time ago.beigg wrote:How so? The anaerobic stuff will never set to dry until both surfaces are tightened down.misha wrote:Bottom surface but make sure that you install it in 15 minutes after the sealant is applied.After that it isn't usable anymore.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
They're just hoping to stealer more of your monies if you believed them...misha wrote:Don't know....that's what i was told at "stealership" a long time ago.beigg wrote:How so? The anaerobic stuff will never set to dry until both surfaces are tightened down.misha wrote:Bottom surface but make sure that you install it in 15 minutes after the sealant is applied.After that it isn't usable anymore.
- misha
Not me....i stopped to believe in them back in 2002.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 17 times
- Been thanked: 35 times
I have some anaerobic sealer in a tray along with the little roller all in a plastic bag that's been there for over a year and it can still be used because it's still very tacky.
