1999 V70T5M56 AC evap 9171781 and heater core 9144221 replacement (Pics end of thread)
Has thanked: 1609 times
Been thanked: 4064 times
98T5 wrote: 10 May 2013, 13:30 Question:
YOu were able to take the dash out one of the doors...I'm wondering if one could also take it out the back tailgate also then? turn it the long way? maybe? no? yes?
I got this out solo but having just done this again on a 99, I have no clue how I did that.
Definitely get a helper on this. Even two helpers standing at each door, with center person guiding it out , clearing wires, is not too many.
The comprehensive list of O rings on the AC system, 1999
Using Volvo Parts Lisle as guide
http://volvopartslisle.com/assembly/790 ... nditioning
Oring - evaporator cold side 3545416 2 on this line (4 total in system)
Oring Evaporator warm side 988840 2 on line this line (3 total in system)
Oring on pressostat valve (low pressure) 3537501 Qty 1
Orfice valve - downstream Oring 3537797 Qty 1 - this one comes with a new orifice valve
Orfice Valve upstream 988840 one on valve, comes with new valve (total 3 in system)
Oring for fill valve NLA? Fill valve is 6849305 - maybe comes with Oring
Oring between condensor and hard lines 9883337 qty 3 total in system
Condensor pipe to condensor hard line - NLA
Condensor to condensor pipe/compressor NLA
Oring from condenser pipe to compressor 6847526
Oring to compressor suction pipe 354441
ORing from suction pipe to drier 9888433
Oring from drier to hard line/evap warm side 3545416 2 at this location, 4 in system
PAG oil recharge by component
When replacing component the oil quantities below apply to the new components:
Receiver/Drier 90 cubic cm
(0.095 US qt.)
Evaporator 50 cubic cm
(0.053 US qt.)
Compressor 200 cubic cm
(0.211 US qt.)
Condenser 20 cubic cm
(0.021 US qt.)
Hose 20 cubic cm
(0.021 US qt.)
Retrospective look at this job
OK - decision time. Ive decided Im going to replace all (eight) cooling group hoses since I want another 50k miles out of this car.
Glad I went OEM, 7 years and 120k miles later
:lol: :lol: :lol:
A Dremel is a god send on this job - that would make removing the evap really easy. Just zip through the aluminum as far in as you can reach to avoid the hard steel lines. Out on the bench, you can easily get the last of the aluminum evap line out with the AC tool from the FLAPS
Bumped forWhite Lightning.
See pictures above on how I cut and removed floor padding to get coolant out
