Have you done a recent compression test?
Idk if it's eating coolant...but it is a possibility, especially for hard cranking. Another thing you can do is pull the plugs and see if one looks "steam-cleaned".
White "smoke" is normal for any car in cold weather, though.
'98 V70 XC - Two problems,
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
mindshadow
- Year and Model: none
Yeah, sorry. It's definitely blue in the morning. Probably is the cold weather for white smoke. Brain wasn't working right there. What do you mean by if the plugs look "steam cleaned"?
Last compression test was probably within the last 1.5 years. None of this crap started until after the most recent mechanic's visit though; it's never been difficult to start. When I pull the plugs they were clean, no oil on them, so that's a good sign. Coolant looked fine. I guess I need to check the oil and see if it's looking milky, to help rule out a head leak.
- osman
- Year and Model: 2002 c70 hardtop
Replace your ECT.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
mindshadow
Three words, and you could be on to something osman. This DID just start when winter finally arrived in Alabama. That plus the erratic thermostat temps. I like this answer better than "your valves are shot" because I have no interest in rebuilding the head.
jblackburn
ECT would explain hard start/fuel smell, not blue smoke, and I would agree. Blue smoke = oil = leaky valves (or oil entering intake from oil-covered hoses/intercooler).mindshadow wrote:Three words, and you could be on to something osman. This DID just start when winter finally arrived in Alabama. That plus the erratic thermostat temps. I like this answer better than "your valves are shot" because I have no interest in rebuilding the head.
Since your PCV was routed incorrectly, it could very well be oil ingested through soaked intake hoses. Pull one off - is it covered with oil?
'98 S70 T5
mindshadow
I'll check it out when I get home. If I can get the hard start dealt with, I'll just have the PCV job done at a good, reputable shop and call it good. Then all I'll need is my driveshaft back and my wagon will be almost new.jblackburn wrote:ECT would explain hard start/fuel smell, not blue smoke, and I would agree. Blue smoke = oil = leaky valves (or oil entering intake from oil-covered hoses/intercooler).mindshadow wrote:Three words, and you could be on to something osman. This DID just start when winter finally arrived in Alabama. That plus the erratic thermostat temps. I like this answer better than "your valves are shot" because I have no interest in rebuilding the head.
jblackburn
Is the oil dipstick smoking when the engine's warm? I thought the PCV had been done recently; just hooked up incorrectly?
'98 S70 T5
mindshadow
There was definitely some back-pressure, but that was before I reconnected the hoses correctly.
PCV wasn't done REAL recently, just within the window of when it should be done. I suspect the shop cut corners, because it's had the blue puff in the morning for a while.
mindshadow
Can the ECT sensor be replaced without draining the coolant? I think I might can pull it without removing the thermostat. The thermostat should be new because I had the radiator replaced probably 15K miles ago so the thermostat should be new (had it done at the good mechanic). Of course I wouldn't know until I pulled it myself I guess.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
If it's like my '96 855 you'll need to drain some coolant — maybe a couple of quarts will do —so you can pull the hose cap off the t-stat housing. I don't think there's another way to get a wrench on the ECT.
If you drain it into a clean container you can put it back into the system when you're done.
BTW: be careful prying the electrical connector apart. While you have that open, clean out any rust or corrosion in the female part—there will be some. You can use a sheet metal or drywall screw with sharp threads. Just scrape up and down. Then a little dialectric grease on the contacts before you plug the new one together will ensure at least that connection won't cause a problem.
- 77 Replies
- 11417 Views
Last post by sleddriver
- 1462 Views
- 644 Views
Last post by equiprx
- 727 Views
Last post by Mike Langlois
- 873 Views
