99 S70 n/a Jumped timing belt, now replacing head
nyurch
- Year and Model: '98 S70GLT '02V70X/C
Lee what are your thoughts about using the same head gasket? And intake gasket? It took me literally 2 hours to get the head off today, would have taken an hour but rose damn 40 valve cover bolts killed me hahaha thanks everyone, you have all been great
- Year and Model: Many Volvos
- Been thanked: 76 times
nyurch wrote:Lee what are your thoughts about using the same head gasket? And intake gasket? It took me literally 2 hours to get the head off today, would have taken an hour but rose damn 40 valve cover bolts killed me hahaha thanks everyone, you have all been great
I would change it since it has been torqued down but, as I said before, I am overly cautious. If I were to go to all the time and effort and then have it not seal there would be an actual haze over my neighborhood from all of the profanity. Since I know this about myself, and to protect the tender young ears up and down the street, I bite hard and open my wallet.
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings. This thread is going to help me a lot. Since I've never order ordered a head before " What comes with a head from Erie? " Your head looks brand new. I thought it would look "recycled". Do I reuse my cams or do they come along ? How long did it take you guys for removal and install ? Did you preset your timing marks on install since the belt jumped? Seeking wisdom and knowledge before I start turning wrenches and spending money.
nyurch
Okay.. from erie it came reconditioned, they sent everything from the head to the cams to the valve cover, all bolts included except the head bolts, and it was like powder coated. Remove and install took 3 freaking weeks start to finish (Take in consideration my work week is wed-sun and did minimal work these days) : 3/30- timing belt jumped, got it towed, 3/31 found out we needed new head, 4/1 called erie and started to dissemble 4/4 received head and started to work. 4/7 got the head on and realized it was vvt- wrong freaking head! 4/8 took the wrong head off and started to wait for the new one.. note: erie was great about it, refunded $55 for new head gasket and sent the right head (the head was $425 and after the mistake was $370.. got new head 4/16 and fully installed everything 4/18 with a very tapping start.. let her run for 30 minutes and now I have a fresh engine. No cel or anything. I would say total cost was around $850 with the head, head gasket set, timing belt set, oil, antifreeze, extra anaerobic sealant, head bolts. And honestly it's not hard, I'm a girl. It was pulling the head bolts to 130 degrees that killed me... first it was the creaking terrified of snapping a bolt and the physical force involved especially on the 12th.
And with timing marks I set the crank and kept checking it and aligned everything with the crank.
And 270 mi on the head I really punched it and what a perfect ride. I had it for sale for 2k for about an hour before it was sold. I have her for another week and I don't want to sell but a neighbor has a pristine 02 xc70 for sale for 3500 with 131k, I know p2 problems but it shifts like a dream and will fit my dogs at the same time.
It honestly was fun doing this. I mean, alot of stress, and problems we shouldn't have encountered but I would definately do it again. Put the gasket for the water pipe on the back of the head before reinstalling, lol that was a bitch, but other than that it was the time that was the worst. The 40 something cylinder head bolts for example! I want to say it took me about 40 hours with half of them being from installing the wrong head first haha
clifford06
Thanks for the info.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Replace the bolts and gasket. As Lee expressed, it just is not worth the risk.nyurch wrote:Yep, I confirmed it, wrong head so erie is sending one tomorrow and refunded 55 dollars for new head bolts. The engine was never fired, so I should be good with the gaskets? Thanks!
- rspi
Contact rspi..
My first go at a head replacement took me 3 days, about 18 comfortable hours:clifford06 wrote:Seeking wisdom and knowledge before I start turning wrenches and spending money.
Day 1: pulled the head in 4-1/2 hours.
Day 2: cleaned the block, cam cover and other parts in 3 hours.
Day 3: installed the head and other parts in 6 hours.
In general, I use to be a slow worker, especially when doing a job for the first few times. I was going to try to do my last cylinder head job in 1 day but as a caregiver I had to many distractions.
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Should I use RTV sealant with the gaskets at the front and rear coolant connections on the head. In your video it's just hanging there with no bolts to hold it up. And because I dropped my labeled bin of bolts do you happen to hav a picture of the bolts for the rear coolant line going into the head?rspi wrote:My first go at a head replacement took me 3 days, about 18 comfortable hours:clifford06 wrote:Seeking wisdom and knowledge before I start turning wrenches and spending money.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
clifford06
Greetings. My question leans toward RSPI. In your video you mention that you like to use the cams to help in head removal. Do you remove the head bolts, then replace cam cover to use cam sprockets as handles to lean head back to break it loose? Your steps for this procedure is much appreciated.
clifford06
Greetings. It's been a minute since my last post. Busted my thumb in a door, waiting for nail to fall off. Watched RSPI' s video again and saw the answer to my question. If no rain or tornadoes, I hope to pull off head this weekend. Updates to follow.
- 17 Replies
- 3531 Views
Last post by Gilly
- 12473 Views
Last post by SuperHerman
- 1702 Views
Last post by jimmy57
- 984 Views
Last post by carboncow
- 2648 Views
Last post by Nick3501
