The paint splotch is unambiguous for sizing front sways. Your s70 base almost certainly has a red one, take a look.
98 S70 When should you replace your stabilizer bar?
- Has thanked: 311 times
- Been thanked: 817 times
There was no s70r
but yes, the thickest ones came on the R and T5 models.
This got me to thinking (Finally! And a first!), so I just went to look. I have a spare red one in the garage, cheap, PM me if interested.
I removed the red bar at 180k when I installed a yellow bar into that car (was engine swapping). Bushings are intact and they were working fine when I removed it.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
There are all difference sizes bushings you can buy.theWIFES_S70 wrote:
For a 20mm bar it's probably a real good bet. And pretty cost effective. Like I mentioned, I really need to get new subframe bushings in there (Proparts wasn't good to me...) and spend the OEM price for them! So saving the $119 really helps out.
Just don't get the greaseable ones.
http://www.energysuspensionparts.com/un ... shings.asp
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
jantt
- Year and Model: C70 2000
- Been thanked: 2 times
Have a 850 1992 and changed the rubbers 3 times. They don`t hold for that long time.
Changed to newer model where the rubbers are vulcanized on. That will last long time.
Remember that we in the mid 1990`s changed stabilizer from loose rubbers to vulcanized ones.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I didn't know that the original model had replaceable bushings! Makes sense. Thanks for the lesson, jantt. The more I think about it, the more I think the Volvo model seems pretty solid. The rubber can last a pretty long time in almost every case.
Retired:
2015 Volvo S60, T5, 85K
jantt
Yours should look like this : http://www.eeuroparts.com/Parts/60841/S ... m-9173982/
If yours is with lose bushing like this (and I don`t think so) then change to vulcanized bar. http://www.pelicanparts.com/More_Info/3 ... 46730-M793
- 10212 Views
Last post by SuperHerman
- 1431 Views
Last post by hu5ker555
- 1234 Views
Last post by jeffsws
- 1279 Views
Last post by Mandude
- 21 Replies
- 3787 Views
