1990 740 gle gas delivery problem?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
joedrt77
Year and Model: 1990 740 gle
Re: 1990 740 gle gas delivery problem?
Post by joedrt77 »
Someone left the inside timing cover off, any way to fix, short of tearing it down? like a after market or modified type cover, probably a dumb question tho, thanks.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I'm running with no timing belt covers. Don't worry too much about it.
1988 Volvo 760 Turbo Wagon
lummert
Post by lummert »
joedrt77 wrote:Thanks again Lummert and regina 93, you guys were right on the money, great advice.
Happy to help.
joedrt77
Post by joedrt77 »
lummert wrote:I'm running with no timing belt covers. Don't worry too much about it.
WOW, you just made my day, I was really dreading trying to tear it down, just to put that cover on, that I would have to find somewhere, THANKS Lummert.
joedrt77
Post by joedrt77 »
Almost forgot, the flame trap is gone, there's just the flame trap box, the rest is missing.
joedrt77
Post by joedrt77 »
Still stalling while idling in park, wonder if it's an intermittent rsr or a vacuum leak because the flame trap is gone?
joedrt77
Post by joedrt77 »
On the key on multimeter test , negetive to ground, positive to either side of the fuel injector connector, I'm getting 12 volts from both sides, is that correct or should one side be 0 or different?, thanks.
lummert
Post by lummert »
Key on, engine not running I get 0.00 volts between both primary connections. Doing it your way I get 12.5 volts from either side to ground. I had the engine stall one due to the coil primary connections were loose enough for one of them to come loose. Before the wire came loose the engine sometimes would act like the key was turned off for a few seconds, then back on. Make sure that the wires to the coil are tight.
joedrt77
Post by joedrt77 »
Does it matter if the sparkplug wires were for a b230 instead of b234? I think they're the same but not sure.
lummert
Post by lummert »
16 valve engine spark plug wire set only fits 88-90 740 B234F and 91 940 B234F. Don't know if that would be an issue.
