P80 headlights Possible to Remove Headlight Reflector, rechroming discussion 8628402 8628403
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2858 times
Been thanked: 1332 times
Post by matthew1 »
With a thin enough material, I think I could reduce the wrinkles to a possibly passable low % of surface area. I'm good with an X-Acto knife, but I've never covered a concave object.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Also -> Amazon link
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
matthew1 wrote: 14 Nov 2021, 17:46 Maybe thin enough, and maybe reflective enough. Maybe.
Perhaps Reflective Mylar. Mylar is good to 200℃
Active
Past
matthew1
Site Admin
Post by matthew1 »
Requirements:
heat resistant to (?)
reflectivity, enough (?)
under $50
easy enough DIY application
long life
Any others?
Also -> Amazon link
RickHaleParker
matthew1 wrote: 14 Nov 2021, 18:19 Requirements:
under $50
long life
Any others?
What I thinking is:
  • 1. Clean the reflector.
    2. Attach a vacuum source to the port the bulb goes in.
    3. Attach or clamp the film to the other side of the reflector, get a air tight seal.
    4. Heat the film and draw it with the vacuum source.
    5. Remove the heat and vacuum let it cool.
If all goes well. this will form a reflective insert that can be bonded to the reflector.
Active
Past
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Seems like this would work fine. And a roll would do 72 cars ! :wink:
1999 V70 GLT
matthew1
Site Admin
Post by matthew1 »
RickHaleParker wrote: 14 Nov 2021, 18:41
Heat gun hitting the outside of the housing maybe?
Also -> Amazon link
dj_v70
Year and Model: v70 2003
Has thanked: 7 times
Been thanked: 23 times
Post by dj_v70 »
Another option, but not as cheap as tape (or film). Heck it is close to the price of a TYC headlight ...
"Great For Re-Plating Headlight Reflectors"
https://www.amazon.com/E-Z-Way-Restorat ... B00HFER3AE
RickHaleParker
matthew1 wrote: 14 Nov 2021, 18:46 Heat gun hitting the outside of the housing maybe?
I would think that by the time a heat gun got it hot enough the reflector would melt.
Radiant heat lamp would have a more even distribution ... infrared space heater aimed at the film?
Infrared heat just what the light falls on.
Active
Past
matthew1
Site Admin
Post by matthew1 »
RickHaleParker wrote: 14 Nov 2021, 18:57
Aimed at the back or the front? The front will reflect most of that energy.
Also -> Amazon link
