Arduino Volvo Display Thread
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
General-purpose Linux is bad for automotive needs. It kills me that the 4D display initializes for more than 3 seconds. RPI boots even longer.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
vtl wrote: 04 Dec 2019, 09:58 General-purpose Linux is bad for automotive needs.
That's disappointing. I love Linux, and am decently handy with it. Thanks for all your input on this. It's extremely interesting.
Also -> Amazon link
vtl
Post by vtl »
There's Automotive Grade Linux :) It boots to operational state in a few seconds. However it's not RPI.
I'm doing Linux kernel for life btw ;)
vonbaron
Post by vonbaron »
Just found and read all this thread and am inspired.
Like you Vitaly, I do hardware and software development, from small Arduino style boards, including DUE and SAMD through to GNU/Linux programming.
Now, this is a neat project and one that I would love to have in my XC70, and as you mention, it's a great way to watch what's going on. I like that I can see the transmission solenoids and the current for the linear solenoids, very cool indeed.
I know I can see this in VIDA, but driving with 'Lappy' running VIDA and Dice cables is not a safe way.
Now, I would not use an RPi in any situation, plain toys in my opinion, not open source, but rather, a better designed and true open source designed such as Olimex based boards.
I'm thinking either to pull out one of my Taiji-uino DUE boards for a play with this or to look more seriously at using the Olimex A20 LIME-II board on the bench idly doing nothing.
With a small SBC like above, running headless Debian (Armbian to be exact), and running a small web server might be interesting, like how 'drieduke' mentioned,
Hi,
Suggestion: instead of this overpriced 4D sys Display, the ESP32 could act as an Webserver to host all the data on a webpage, so one could just use its smartphone as Display.
It could be programmed up in either C/C++ or I suspect quite well in Python 3.x too, which is where I have been spending a fair bit of my time in recent months. One process for polling CAN data and stuffing that into a memory map area or REDIS instance, with another process being the web server pulling stuff from REDIS when web clients wants data.
I use this approach for my developing industrial SCADA system, which sort of what this is, right :D
The idea of using a web server doesn't necessarily mean using a smartphone to have a display, but offers many more possibilities for various displays, such as WiFi connected Android tablet, connected display via HDMI to monitor with SBC running a web client application as well.
Using a SBC like an Olimex A20, means you can have a SATA drive, say solid state (SSD) and then that allows a lot of data to be stored. The SBC has Ethernet, so connectivity to your home network to update the application or to download stored event data is easy. Imagine, logging and storing sensor data for anything you want or need that can then be view on screen in any number of good javascript charting libraries. As well, the data can be exported and viewed in any other manner a person feels comfortable with, even if they do elect to use MS Excel :twisted:
Well, this is a fantastic project, I will keep this up in my list of open browser tabs and think more on over the coming while :)
I've checked out the Arduino code and it all make sense to me, so keep up the excellent work Vitaly and others.
Von Baron
vtl
Post by vtl »
The new hw is not robust enough to poll the data like Due does (MCP2515 has a shallow tx buffer?). I redid the sw to use A5/A6 XX ... 02/03/04, the CEM should send the needed data repetitive on its own, but didn't bother to test it yet.
The Arduino code is pretty much a generic C with some bits of C++. Adapting it to any other OS is not a big deal.
milzinger
Year and Model: 2003 S60R
Post by milzinger »
Hello, I know this is a very old thread, but can someone explain me how to find the required bits in the vida sql database? In my case it is an S60 built in 2003 and model year 2004.
Many many thanks
Andreas
vtl
Post by vtl »
milzinger wrote: 26 Jul 2023, 04:06 Hello, I know this is a very old thread, but can someone explain me how to find the required bits in the vida sql database? In my case it is an S60 built in 2003 and model year 2004.
Many many thanks
Andreas
What are you looking for specifically?
Generally speaking, I was reading sensors in VIDA to have modules IDs logged in C:\VIDA\System\Logs\Diagnostics.
You can run this SQL query to figure out what module is this or that ID:
Then I came up with this query that fetches bit offset in CAN message and its conversion formula:
milzinger
Post by milzinger »
Many thanks for your response. I would like to have a canchecked display in my car. In my case an MFD32s. I have used add-ons from PLX Devices in the past. Unfortunately, the OLED displays here are defective after 15 years and the manufacturer no longer has them in their range. Unfortunately, Canchecked has no idea about Volvo and would need the addresses (ID's). I was hoping to find out quickly and easily. I'm not familiar with bus systems and I had very little to do with SQl either.
vtl
Post by vtl »
milzinger wrote: 31 Jul 2023, 03:11 Many thanks for your response. I would like to have a canchecked display in my car. In my case an MFD32s. I have used add-ons from PLX Devices in the past. Unfortunately, the OLED displays here are defective after 15 years and the manufacturer no longer has them in their range. Unfortunately, Canchecked has no idea about Volvo and would need the addresses (ID's). I was hoping to find out quickly and easily. I'm not familiar with bus systems and I had very little to do with SQl either.
This is not OBD PIDs, Volvo uses its own protocol. The device in this topic works using this same protocol.
milzinger
Post by milzinger »
Thanks very much. Yes I think I understood that. According to the manufacturer, the new display that I want to install should understand the Volvo Can protocol if it knows the IDs. If I remember correctly, Volvo has often changed the ID's on the P26 platform. I think I'll have to talk to the manufacturer again in more detail.
