Do I check for vacuum at MAP sensor riding on the hose to ETM? Probe for opening and closing?vtl wrote: 28 Sep 2020, 20:02The last things to check are the wastegate adjustment (https://www.matthewsvolvosite.com/adjus ... wastegate/) and whether MAP sensor is faulty/lying. If everything is fine, it all points to the ETM, I think.
2001 V70XC - struggles to idle when coming to stop light Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Unfortunately you can only reliably test it by swapping with a known good one and driving through the pattern which was causing problems previously.xHeart wrote: 29 Sep 2020, 11:21 Do I check for vacuum at MAP sensor riding on the hose to ETM? Probe for opening and closing?
xHeart
Very helpful vtl.vtl wrote: 29 Sep 2020, 11:27Unfortunately you can only reliably test it by swapping with a known good one and driving through the pattern which was causing problems previously.xHeart wrote: 29 Sep 2020, 11:21 Do I check for vacuum at MAP sensor riding on the hose to ETM? Probe for opening and closing?
I'll see if O'Rielly's have the gauge in the rental tools list, like the one in IPD's video. HFT do not show such tool, but can the A/C manifold be jigged for wastegate application?
xHeart
Yes, unless there are other DIY ways. O'Reilly does not have such tool.vtl wrote: 30 Sep 2020, 07:32 Gauge for the wastegate adjustment? A/C gauges are for hundreds of PSI, you need like 5.
I wonder if my MityVac 8000 can be configured, here is the manual: https://manuals.harborfreight.com/manua ... /39522.pdf
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Don't know if yours has the same feature but my MityVac 8500 can perform both vacuum or pressure. The gauge has a neg vacuum and a pos pressure reading. You need to turn the knob on the left down to get pressure.
xHeart
After removing engine brackets, heat shield, and various hoses around the turbo, the task for the wastegate and bypass valve becomes visible but physically stretching.
Since both wastegate and bypass valve hold vacuum, I'll thoroughly clean and put is back together for a drive with new MAP this weekend. This drive may firm my next steps...
A turbo service and exhaust seals appears to be the next.
I have the IPD wastegate pressure tool in my instruments box, would fit in the smallest USPS ship box nicely.
xHeart
Wastegate would be my next step, before taking up ETM.abscate wrote: 01 Oct 2020, 10:27 I have the IPD wastegate pressure tool in my instruments box, would fit in the smallest USPS ship box nicely.
SO, a 10 miles test drive did not show any hesitation when coming to stop and idle.
Thus far, I've replaced large hose between MAF and turbo, MAF, TCV, MAP, and replaced the green, yellow, red, and blue vacuum lines. The wastegate (yellow line)) and bypass valve (green line) hold vacuum.
In the following description ECM-6806 and MAF appear in same sentence for signal too high.
Code: ECM-6806
Definition: Turbocharger (TC) Control System, Flow Fault Too High Or Too Low
Description: If engine speed (RPM) is above 3500 rpm and the engine is operating at a high load, the control signal to the turbocharger (TC) control valve is at maximum and the boost pressure (from boost pressure sensor) is lower than a designated value (approximately 20 kPa (2.9 psi) under normal boost pressure - signal too low). If the air mass (from mass air flow (MAF) sensor) is higher than a desired value (signal too high) it is interpreted as a fault and diagnostic trouble code (DTC) ECM-6806 is stored.
Cause:
Signal too high:
Air leakage after turbocharger (TC)
Signal too low:
Hoses between turbocharger (TC) and turbocharger (TC) control valve respectively Turbocharger (TC) control valve and pressure servo are loose or are blocked/damaged
Faulty turbocharger (TC) control valve
Faulty boost pressure control (BPC) valve pressure servo
Sticking boost pressure control (BPC) valve
- 1828 Views
Last post by Livens
- 529 Views
Last post by jreed
- 58 Replies
- 11080 Views
Last post by precopster
- 3297 Views
Last post by 00VolvoS70NonTurbo
- 413 Views
Last post by volvoscrub
