'94 850T - Sudden Oil Leak at Front / Forward Side of Block
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
BlackBart wrote: 01 Oct 2020, 07:34
ZionXIX wrote: 30 Sep 2020, 20:19 Have you considered adding a little dye to the oil and letting it idle at night with a UV light and watch where the oil is coming from?
I've never done that - where do you even find each of those?
Related question - Is there a thermostat in that oil cooler line? Are those lines not under pressure until high engine temps?
The oil cooler lines connect to a thermostat that is mounted on the oil pan. This is the other half of the installation PITA that was mentioned upthread. There are issues to watch out for with o-rings, with the retainer clip, with the thermostat itself bending. I'd suggest do just a little reading about how to install these before you get started on any replacement project.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Right - understood.
But at normal operating temp after just idling, is there flow and pressure in these lines for the UV leak test? Or only at higher temps under load?
