4-5 frictions wear quicker then the rest.
There are couple of common wear spots on the casing. Depending on how bad is yours, it would make more sense to acquire a low-mileage donor gearbox. Or have your casing fixed. @firstv70volvo kindly did such the fix for me (brought the casing to Omega Machine for steel sleeve).
The rest is more or less simple, just get a factory new valve body, don't mess with yours.
Is it time for a new automatic gearbox ?
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Vtl and I have rebuilt this transmission and can help with photos and instructions.
It's a big job so you'll need to do some planning up front as far as what tools you'll need, parts you'll need, space and time you'll need.
You'll need about 5 full days to complete this job. It took me a day to remove the engine and start disassembling the transmission, 2 days to rebuild the transmission and another day and a half to install the transmission and sort everything out.
You'll need a transmission rebuild kit ~$500, ATSG manual $55, remanufactured torque converter $150 to $300, new valve body ~$500 and whatever tools you may need. You mentioned you've replaced the valve body about a year ago and if it was a new valve body and it's still working well then you can reuse it but a worn valve body or sticking linear solenoids can cause a lot problems so error on the side of new replacement.
For tools you'll need an engine support bar, a transmission jack or an engine hoist to lower and raise the transmission and some tools you may not have to rebuild the transmission like a spring compressor, clamps, horseshoe ring pliers, etc. but overall there's not many special tools needed to rebuild this transmission.
I have a lot notes and photos if you decide to do this and there's some good disassembly and build videos on Youtube for this transmission.
Here's a good build video, most videos are just showing how to tear them apart, this one shows how to rebuild it too.
As Vtl mentioned the case could be worn in a couple of areas and there could also be some hard parts that need to be replaced so it might be best to find a good used transmission to start with and there are advantages and disadvantages(cost mainly) of rebuilding a good used transmission ahead of time.
greffel
- Year and Model: 2003 S60
- Has thanked: 11 times
- Been thanked: 7 times
The vibration that I feel on the 4 gear, would that be worn clutches or a worn case ?
Why do I need a new torque converter ?
Polestar 2 - All electric daily driver
S60 2.5T AWD with a little bit more power
greffel
Have looked now for 2 weeks after a replacement gearbox. A gearbox from a 2.5T is no where to be found.
There is a R box available....but will it fit and work?
On a manual gearbox the number down right on the gearbox sticker is the ratio ex. 3.77
Can't find the equivalent on my box
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Not your model year, but MY2006 and MY2008 were 2.27:1
https://www.media.volvocars.com/us/en-u ... ifications
https://www.volvoclub.org.uk/tech/s60-06-specs.shtml
greffel
And the R was 3.33
https://www.volvoclub.org.uk/tech/r-06-specs.shtml
What will happen if a R gearbox goes on to my car ?
Haldex and/or diff will take damage because the different final drive?
