Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
gajoss wrote: 04 Feb 2026, 09:28 How do I find the correct shuffle order? Is there a way to do that?
Find you CEM p/n in the source code, change last number in array (usually 0), try to crack, repeat.
gajoss
Year and Model: V50 2005
Has thanked: 2 times
Post by gajoss »
vtl wrote: 04 Feb 2026, 09:39
Confirm if I'm thinking correctly. Red - my CEM number. Yellow - I change the digit - I change the shuffle order of the PIN bytes.
Volvo CEM shuffle order.jpg (41.47 KiB) Viewed 1061 times
vtl
Post by vtl »
gajoss wrote: 04 Feb 2026, 10:08
Yes, change it to 2. Also read this: viewtopic.php?p=592875#p592875 We need to change shuffle order for 8690720.
vfred748
Year and Model: S60 2006
Post by vfred748 »
vtl wrote: 22 Jan 2026, 09:49
vfred748 wrote: 22 Jan 2026, 09:26
vtl wrote: 21 Jan 2026, 14:34
No way it can't work on the bench. I spent long months with CEM-L on the bench, hundreds of runs.
So i will make it on car, thanks for the advice. 👍
I said it works on the bench. I ran it once, maybe twice on a real car :) Remove autodetect line, compile/upload, wait for the message, power up the CEM quickly.
Hello the forum,
Sorry for the late for upadting my posts.
I have sucessfully read the pin on the bench, I've changed the can module, maybe the old one was dead.
To resume :
On the CEM
PIN 8 15 & 16 on +12v
PIN 6 on ground (same as the ground on teensy)
PIN 33 & 48 on CAN HS
PIN 40 & 55 on CAN LS
I've booted the CEM cracker & the CEM at the same time with a stabilized power supply.
About 15-20 minutes and the PIN code appear :D
Great job & thanks for your help.
vtl
Post by vtl »
vfred748 wrote: 08 Feb 2026, 12:52 Hello the forum,
To resume :
On the CEM
Congrats! Now you can crack pins for your friends ;)
vfred748
Post by vfred748 »
vtl wrote: 08 Feb 2026, 14:29
To resume :
On the CEM
For sure :mrgreen:
Unfortunately, I don't know any Volvo driver, but I will help anyone in need.
Greetings from France
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Has the CEM cracker been tried on the later delphi CEM's?
Like these one's?
vtl
Post by vtl »
oscilloscope wrote: 14 Feb 2026, 02:31 Has the CEM cracker been tried on the later delphi CEM's?
Like these one's?
Is it SPA?
poteroa
Year and Model: 2001 V70
Post by poteroa »
Hi all.
Quite massive page count on this topic..
Have a question, and maybe someone can answer directly without need to go through 430 pages :D
Just read the CEM on a V70, 2001 and looking for the PIN. (And IMMO code of course if it is possible to decode from there)
I used the kaev´s Arduino BDM soft, the only problem is that you can not save the read binary with that software.
https://volvo-tech.com/en/793-2/ (Used Arduino UNO for this, as it was easily available).
Going through the peoples replys, I found info that the PIN should be located in address 0x04E000 is this right?
Do not see any sense to buy expensive programmer just for getting one remote programmed to otherwise cheap car.
Anyone able to help on this?
Oh, the CEM unit is HW-PN: 9452596
Other markings: 8645697/01W075
oscilloscope
vtl wrote: 14 Feb 2026, 08:35
Like these one's?
Is it SPA?
It might be yes , i tallied up the type and compared it to xprogs connnections via bdm, now at first , I saw a locksmith wiring up a xhorse programmer to the BDM connections, and i wondered if the cem cracker has been tried out on them newer cems.🤔
