For devices for which I do not have physical access, it will be difficult, without USB sniff logs. For DiCE it might be possible, but it will mean that users will have to be guinea pigs.MotorolaV3X wrote: 27 Aug 2026, 03:13 Hello dikidera, will it be possible to work with other adapters? sm2pro or dice
Vida CEM swapping
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
- RickHaleParker
- Been thanked: 977 times
Anybody got an extra DiCE or other interface ? To send to dikidera for further Moose Diag development.dikidera wrote: 27 Aug 2026, 09:34 For devices for which I do not have physical access, it will be difficult, without USB sniff logs. For DiCE it might be possible, but it will mean that users will have to be guinea pigs.
Active
Past
Past
dikidera
Actually USB sniff logs would work much better. That is all I need. DiCE unlike other J2534 devices has parallel communication, meaning it likely contains 2 CAN bus transceivers to communicate over HI and LO speed busses at same time. VIDA source code event makes that distinction.RickHaleParker wrote: 27 Aug 2026, 13:53Anybody got an extra DiCE or other interface ? To send to dikidera for further Moose Diag development.dikidera wrote: 27 Aug 2026, 09:34 For devices for which I do not have physical access, it will be difficult, without USB sniff logs. For DiCE it might be possible, but it will mean that users will have to be guinea pigs.
67726567
- Has thanked: 1 time
- Been thanked: 2 times
What do you mean by USB sniff logs? Are you needing someone to use a logic analyzer on the DICE?
I have used an Autel j2534 VCI for VIDA in the past, FYI. So, the driver functions should be well know/ documented. It would communicate on the entire network at once.
Or, do you mean VIDA logs?
I can get logs for you but I don't know about testing. I am sure of your capabilities but I would be giving you logs from reading customer vehicles.
By the way, I am figuring out the P2 XC90 CAN broadcast data.
My DBC is here:
https://github.com/gregoryables/Volvo.P2.XC90.CAN_RE
I'm not done with it yet and there may be errors from the fact that I've not fully identified everything yet *and* I've used a 2008, a 2010 a 2011 *and* a 2013 to identify the signals with. I have eliminated nearly all of the erroneous inclusions because I now have three different 2013 captures to validate against.
However, I have yet to validate the DBC against a known good 2013 XC90. That will be necessary before I consider this to be anything other than a pre-release file.
My DBC is here:
- RickHaleParker
A USB sniffer eavesdrops on the USB conservation and records it to a log file.67726567 wrote: 30 Aug 2026, 13:28 What do you mean by USB sniff logs? Are you needing someone to use a logic analyzer on the DICE?
Active
Past
Past
- RickHaleParker
I am working of a Android-DiCE API and SDK. Lets see if I can pull it off. That would open the door for other Android apps to use DiCE.dikidera wrote: 29 Aug 2026, 23:52 Actually USB sniff logs would work much better. That is all I need. DiCE unlike other J2534 devices has parallel communication, meaning it likely contains 2 CAN bus transceivers to communicate over HI and LO speed busses at same time. VIDA source code event makes that distinction.
Intending to do the same for Linux-DiCE.
"VIDA source code" You lucky guy now did you get that?
Active
Past
Past
67726567
I am aware of what a USB sniffer is. I also know that English is not dikidera's native language, so I want to be sure.RickHaleParker wrote: 30 Aug 2026, 14:08A USB sniffer eavesdrops on the USB conservation and records it to a log file.67726567 wrote: 30 Aug 2026, 13:28 What do you mean by USB sniff logs? Are you needing someone to use a logic analyzer on the DICE?
I have a RotKee USB analyzer and a BusPirate.
- RickHaleParker
Europeans often know English better then some American do.67726567 wrote: 30 Aug 2026, 14:31 I am aware of what a USB sniffer is. I also know that English is not dikidera's native language, so I want to be sure.
Active
Past
Past
67726567
Okay. Well... I'll be around.RickHaleParker wrote: 30 Aug 2026, 14:41Europeans often know English better then some American do.67726567 wrote: 30 Aug 2026, 14:31 I am aware of what a USB sniffer is. I also know that English is not dikidera's native language, so I want to be sure.
- RickHaleParker
Might be able to get what you need from a bench CEM.dikidera wrote: 29 Aug 2026, 23:52 Actually USB sniff logs would work much better. That is all I need.
- Which operations you want captured.
- Preferred format.
What do you need to know?
Active
Past
Past
- 8865 Views
Last post by RickHaleParker
- 8661 Views
- 27 Replies
- 27393 Views
Last post by cn90
- 10061 Views
Last post by jonesg
- 5321 Views
