Bulbs, bulbs, bulbs...interior bulbs.
This topic is in the MVS Volvo Repair Database » Interior bulbs designation, sizes, etc.
tailor
Year and Model: 2004 XC90 2.5T AWD
Been thanked: 2 times
Post by tailor »
TIP: there are a LOT of lights in the instrument cluster. Carefully write down which areas are dead before you take everything apart. You want to avoid having to repeat the removal because you missed one (I did).
I am sure that a lot of folks know this, but..if you do not, you can either back probe the bulbs using a continuity meter with tone or remove the bulb and check it. No tone = bad bulb. If you have no meter use a 9v or similar battery, with wires attached, one to each of the positive and negative terminals, to check the bulbs in question and place one wire on each side of the bulb holder......no light= bad bulb :shock:
Below is a pic of back probing
And a pic of the back of the cluster
The process of back probing is most likely a little quicker than writing it all down and some areas may be "dead" by design, like the two blank inserts, which have no bulbs. Of course all this knowledge is usually obtained once the cluster is out anyway!
BTW: Meters are really inexpensive now and if you are going to do some "wrenching" it is a good addition to the "stable" of tools.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
pfk1006
Year and Model: 1998 S70 GLT
Post by pfk1006 »
MadeInJapan wrote:Certainly-
I hope this helps: http://volvospeed.com/Dashremove.php
MIJ, thanks, would this process be the same for a s70? I don't recall my vents rotating.
BTW, my s70 glt is the same color scheme as yours, nice looking car, huh? I just passed 200k miles.
Thanks again.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
the Vents are different but basically the rest is similar enough you'll figure it out! I just turned 170K miles today...still runs very very strong- great cars for sure (S70's)!
pfk1006
Post by pfk1006 »
MadeInJapan wrote:the Vents are different but basically the rest is similar enough you'll figure it out! I just turned 170K miles today...still runs very very strong- great cars for sure (S70's)!
MIJ,
Thanks for your help, got the bulbs replaced, no issues... :D
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
Apologies if I have missed this, but I've read this thread 3 times now and I'm not seeing the answer. Anyhow, the bulbs that are in the rocker switches on the panel (ie. fog lights, locks, sunroof, heated seats, etc) on my 97 855 are socketed, but is there an inexpensive replacement other than the dealer or 'modifying' the bulbs as outlined in this thread?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
There are no off the shelf replacements that I know of - they seem to be uniquely Volvo.
zhenya
Post by zhenya »
Thanks Lee. I'm finally getting around to replacing all of the dead interior bulbs. I inquired about replacing the seat heater one above. Do those switches just pull straight out as the ones on the dash do, or do they require disassembly of the console?
Post by Ozark Lee »
They pop out like the switches on the dash.
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
If the 850 rocker switch bulbs are the same as those in the V70 there are identical yet much cheaper replacements to be had at Honda (they are used as clock bulbs in some Hondas). I posted the part numbers here a few months ago. Although most of the Volvo switches use a bulb identical to the Honda bulb, some use bulbs with unique long-stalks. I simply replaced those with the Honda bulbs too, and they work fine.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
zhenya
Post by zhenya »
Thanks instarx. I actually replaced all the bulbs in my radio yesterday with the Honda bulbs. A couple of the bulbs weren't bad, but I replaced them all to save me the trouble again in the future. I'll try the good ones in some of the rocker switches that are easier to access.
