850 automatic transmission
This topic is in the MVS Volvo Repair Database » Classic PNP Switch Shifting Fix
milesursogood
Year and Model: 850 T-5, 1997
Post by milesursogood »
[quote="MadeInJapan"]No, it's not the same...actually there is a transmission speed sensor which causes the engine to run at different speeds as well as a Vehicle Speed Sensor...I'll post both fixes from VADIS below:
madeinjapan, i'm assuming the vehicle speed sensor has anything to do w/ the faulty gearbox problem in this thread?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I don't have a clue- the thread is over 2 years old- I'll go back and re-read....
donis222
Year and Model: S70 T5 1998
Post by donis222 »
:) My 855 has had a hesitation (slip) that was worse in the cold. After much searching and a flush, PNP cleaning and a valve body cleaning, I found the problem. The seals on the transmission get hard and don't seal well, especially when cold.
I used Lucas transmission fix and after a week the problem is largely solved. This allows fluid to leak aroung the seals and increases the time for the pistons to lock the clutch.
There are a number of products that may work just as well. I am angry with myself :x as I knew this from many older cars. The problems that I had experienced with them was not shifting into gear when cold. These were the transmissions that didn't rely on solenoids to shift, but pistons to open and close passages.
