Transmission Flush not recommended for 850's
This topic is in the MVS Volvo Repair Database » How to Not Break Your Transmission
firestarterpro
Year and Model: 850 NA - 1995
Has thanked: 2 times
Post by firestarterpro »
I'm assuming this applies to automatic and standard? I have a stick with a new transmission at about 100,000 miles on it.
94 850 NA
._____________,
||------|---||---||__\ \___
\=-(@)-===-(@)-=*B
The proudest owner of a Naturally Aspired 2.4L Volvo 850 Wagon of 1995!!! :o :o :o
94 850 NA Wagon was hit and totalled at 350k :oops:
96 850 NA Sedan sold at 180k :arrow:
95 850 Turbo Wagon sold at 260k for parts :!:
95 850 NA Wagon sold at 220K :arrow:
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Manuals have a lower drain hole and upper fill/level check hole. They also use different fluid. So, get the proper fluid and drain and fill it. It also is NOT connected to the radiator.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Auto only. Stick has its own transmission oil which is quoted as being "lifetime." With replacement of the original clutch at 229,500 miles, I asked my mechanic to change the transmission oil. I used the ferociously expensive Volvo transmission oil. He said the stuff he drained out looked perfect and he wouldn't have changed it on his own car. I think you're ok leaving well enough alone on a standard.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1610 times
Been thanked: 4065 times
I did my first manual transmission oil change on the 1999 at 165k miles, using Valvoline synthetic, and I suspect the only benefit was padding my thread and post count on MVS. No particles, corrosion, or nasties evident. Car shifted exactly as same as before AFAIK.
Not counting the benefit of gloating about having a stick to Matt again...
Redneck
Year and Model: Volvo 854 1996 GLT
Has thanked: 10 times
Post by Redneck »
At around 60-70K miles oil change service "scammed" the owner into transmission flush. Years later when I looked at the service record, I thought.. Wow..that was the best "scam" ever. I never had to worry about flushing the transmission myself later. I do it every 2-3 years now. Transmission works very well. Sometimes it is worth it to get "scammed":)
I would pour seafoam transtune in and drive with it for 2 weeks, then drain and flush (home method. Don't do the power flush) it yourself no matter what. Take the risk. If it failed, I would buy a new car. The gears must not be switching properly if it has never been flushed. Why drive a car like that. If the transmission is so bad that fails from changing fluid, it is already on a borrowed time and will fail in the middle of the road somewhere.
The non synthetic fluid becomes brown after 3-4 years. If it has never been changed, it must be black and burnt after 18-20 years.
Before doing any other repairs, the transmission should be taken care of first, otherwise all other work will be a waste of money if the car needs to go to the junk yard due to transmission replacement cost.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
Is there any way of knowing what sort of fluid is in a transmission, short of sending it away for analysis?
If you were going to drain a transmission, whose contents are ultimately unknown, would you drain and fill over a few weekends/weeks (with the same fluid) to get all the old stuff out? Is that the process?
Retired:
2015 Volvo S60, T5, 85K
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
theWIFES_S70 wrote:Is there any way of knowing what sort of fluid is in a transmission, short of sending it away for analysis?
I personally would go with the factory recommended ATF type, Valvoline Maxlife ATF is good for the price. Aisin Warner makes good ATF and they just happen to manufactor transmissions on Volvo vehicles.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
theWIFES_S70
Thanks, Shiloh!
Retired:
sk55
Year and Model: v70r 1999
Post by sk55 »
i just replaced mine on my s70....
i used a mity vac sucked out 2 quarts... put in 2quarts of valvoline max life red bottle...drive it 50 miles. did this 7x...
i plan to do replace 4qt next year good way to replenish additive pack in the oil.
she runs great!!!....
dreiduke
Year and Model: XC90 2004 D5 AWD
Has thanked: 5 times
Post by dreiduke »
i owned many automatic cars.
2 Mercedes MJ 1990 (about)
Volvo S80 MJ 2000
BMW MJ 1999
F150 MJ 1999
XC90 MJ 2004
and i flushed every Transmission, as soon as i got the car.
everytime, it leads in a smoother Tranny
last week i installed a new/used Torque converter, because mine was cracked on the XC, i filled the tranny with new but wrong oil, drove two days, and flushed it, and this was good, the used converter was full of old black oil and particles.
now its smooth again.
its not the metallic particles, which ruin your transmission, its the particles from the frictions and brakes in it. microscopic metallic particles act more like a kind of lubrication (colodial), but particles from frictions act like sandpaper, and they should be removed from transmissions.
and then there is a point.... additives.
each tranny, needs special additives in its oil, which have more ore less friction characterisics
my opinion
