1998 s 70 t5 cold start whining engine noise
fields 100
- Year and Model: s 60 T-5 2013
Replaced the original stat with a 187F Wahler. Still the same whining noise. Is it possible that the oil cooler thermostat malfunction can cause such a noise? I believe it is located by the crankshaft pulley. Thanks.
SpeedyPete
- Year and Model: S70-T5, 1998
Fields 100, Headshot10: You want some CHEESE with that whine?
Forget science. There is nothing so uncommon as common sense! Milage doesn't matter, the cars are old. They are like women. You need to warm them up a little bit before.....driving them! My baby makes all kinds of moans and groans for a couple of minutes before she begins to purr. Best Regards, SpeedyPete
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I have something that I don't think has been mentioned here. Your car has the fuel pressure regulator in the fuel line just behind engine at firewall on passenger side. There is a vacuum line that goes over top of engine, 8mm steel pipe that looks like a fuel line and sits next to the fuel line on top of engine, and if the T fitting at FPR gets cracked it whines/hisses.
My 98 got a crack in a rubber piece at that T and I stethoscoped a tone of stuff with no results. I put it on lift and had it running and found it from below.
- 18 Replies
- 5490 Views
Last post by Skymongrel
- 2461 Views
Last post by Ou2mame
- 4762 Views
Last post by plafratt
- 2547 Views
Last post by mcleish
- 54 Replies
- 14251 Views
Last post by Caineyanko
