2000 S70 Transmission project Topic is solved
Has thanked: 1497 times
Been thanked: 3809 times
Re: 2000 S70 Transmission project
What are you going to use to wash filter so you can reuse it?
(Ducks)
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Put back the valve body and hooked it up. Kit came with a cork gasket.
BMW 540i 2002
S70 Base 2000
That looks f-gorgeous...can't wait to see it running
kallekula
Post by kallekula »
New rear main seal and torque converter:
BMW 540i 2002
S70 Base 2000
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Best to be safe; good work!!
kallekula
Post by kallekula »
I thought I would have my car back on the road today but nope. Transtar sent me the wrong converter...
Got the rear main seal installed and that's where I am now.
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
New converter
BMW 540i 2002
S70 Base 2000
kallekula
Post by kallekula »
Almost there. Put the tranny back the other day and it works ok but not 100%. There are some bangs and a little bit of shift flare when taking off. Gonna try and calibrate the solenoids first and if that doesn't work I will take a look at the valve body.
BMW 540i 2002
S70 Base 2000
precopster
Great job!! Did you remove and check/replace the B4 servo cover? If the internal washer on the cover is detached or bent flaring b/w 2-3 is the symptom. Also how many millimetres of wear does the B4 band have left? Refer this thread: https://www.matthewsvolvosite.com/forums ... hp?t=63881
The model year you have will take around 600 miles to adapt to the new hardware. Take it from me you need to drive it to see. Make sure you reset the adaptives and the fluid counter. There is no drive cycle in the P80 TCM so that's why you just need to drive it. I have no idea how Volvo used to prepare these for sale without an adaptation cycle.
kallekula
Post by kallekula »
Didn't replace the b4 cover. I didn't have any problems with shift flares before it went out.
My guess is I screwed up the solenoids when I replaced the bushings. To be honest I mixed up the springs/parts for the SLS/SLT solenoids. Everything looked the same so I assumed it would be fine. No idea if that is the cause but as a first step I will go to PickYourPart and buy a "new" set and take it from there.
BMW 540i 2002
S70 Base 2000
