I may have something on that in the next few days.maverickbna wrote:Is there any way to get the actual mileage from an OBD-II ECU? I have a '96 850 base model, and the odometer's stuck at 51,723. I just got stuck with a 'not actual' branded title, and now that I know that it's a broken odometer gear, I'd like to get my local Volvo repair shop to get it fixed!
I wouldn't mind repairing other stuff, but this sounds a little too complicated to do the odometer repair!
How to read your actual miles from the ECU
How to Read Actual Miles from the ECU
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Ambitious but rubbish
petek153
- Year and Model: 1992 940T
On 1995 and earlier, you can read the ECU mileage from the diagnostic port as follows:
1. Select module A terminal 7
2. Switch ignition on
3. Push button 5 times
4. When LED comes on and stays on, enter code 1-1-1 as follows:
- press the button once when LED is still on
- wait for LED to go out and come on again
- read off response, which will be the last three digits of the odometer miles
5. Repeat steps #3-4, but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
ERO1
- Year and Model: 1996 850GLT ; 2007 X
- Been thanked: 2 times
Hi guys, I am having the same issue...how to find out the mileage from the OBD II....I took it to my local mechanic and although he could read the codes he did not know how to read the mileage. Neither did a mechanic who specializes in "foreign" cars, nor my Volvo dealership. The dealership told me that they could not retrieve that info on older than '98 model OBD II's. If anyone can tell me how to read the codes it would be very much appreciated! I have no problem fixing the odometer, the tutorial is great and I already have the gears....just would like to be able to set the mileage correctly.....Thanks!tjts1 wrote:I may have something on that in the next few days.maverickbna wrote:Is there any way to get the actual mileage from an OBD-II ECU? I have a '96 850 base model, and the odometer's stuck at 51,723. I just got stuck with a 'not actual' branded title, and now that I know that it's a broken odometer gear, I'd like to get my local Volvo repair shop to get it fixed!
White 1996 850GLT first Volvo.... loving it!
Magic Blue 2007 XC90
ERO1
https://www.matthewsvolvosite.com/forums ... =1&t=43723
Check this thread as Jimmy57 has the procedure and the tech at my Volvo dealer said that is correct......I did finally find a dealer who could do it for a nominal fee...not many out there.... Good Luck!
9394volvo850s
- Year and Model: 93 850 5spd 94 850T5
i tried this in my 93 5speed 850 and it said there was 157 miles less on the cluster then on the ECU 320K. maybe it broke at one point? lol, my 94 turbo says 190k but ecu says 193k. i bought the 94 from a younger volvo tech so maybe he replaced the gear. also i had that ecu tuned and i used it in my old 95 850 turbo while i was making upgrades to the 94, so maybe thats where some of the miles came from. I cannot get an accurate reading on my T5R wagon. i know the odo was broken on it from the previous owner. odo says 138k he said about 180k actual. i put 3k on the car since ive had it and i just got a possible 184k from the ecu. wich would have ment 181k when i got it so pretty close.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k
Just to clear up any confusion, mileage is stored in the cluster itself not the engine ECU on ME4.3 and ME4.4 cars. When you use the OBD I under hood connector and read mileage it is communicating with the instrument cluster.9394volvo850s wrote:i tried this in my 93 5speed 850 and it said there was 157 miles less on the cluster then on the ECU 320K. maybe it broke at one point? lol, my 94 turbo says 190k but ecu says 193k. i bought the 94 from a younger volvo tech so maybe he replaced the gear. also i had that ecu tuned and i used it in my old 95 850 turbo while i was making upgrades to the 94, so maybe thats where some of the miles came from. I cannot get an accurate reading on my T5R wagon. i know the odo was broken on it from the previous owner. odo says 138k he said about 180k actual. i put 3k on the car since ive had it and i just got a possible 184k from the ecu. wich would have ment 181k when i got it so pretty close.
I've read and watched a lot of threads on retrieving the mileage on these cars and there is a consistent theme in that usually the stored or retrieved mileage is usually higher than what the odometer indicates, usually by a few hundred miles. I have even noticed that after 1k miles the mechanical odo and the electronic odo on the trip computer are usually off a tenth or so; I'm sure that'd add up over time.
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
9394volvo850s
oh ok, i was under the impression that it was stored in the ecu. so im gussing in that case that my 94 turbo must have been broken at some point breifly.
Yes this seems to work just fine. My odometer has been inop since 99,000 and I salvaged a used odometer with 124,500 on it and now I know my vehicle currently has 123,891....too close to worry about changing! Thanks for the tip.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
blackcomb1
- Year and Model: 1995 Volvo 850 GLE
none the wiser this end, fly wire (where is that located?) silly question maybe but I have never done this btw.
I am 100% a woman.
- 3135 Views
Last post by Rucho26
- 1994 Views
Last post by coflynn
- 23 Replies
- 3967 Views
- 1687 Views
Last post by 850_GLT_Owner
- 4003 Views
Last post by jonesg
