2012 S60 T5 blown engine, replaced under Volvo Goodwill Topic is solved
This topic is in the MVS Volvo Repair Database » 2012 S60 Blown Engine
bkw1962
Year and Model: 2012 S60 T5
Post by bkw1962 »
Do tell.....did you deal with Tracy Herman of Volvo USA in Philly?
djtomr941
Post by djtomr941 »
Yes.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Is there more information to be had about this problem generally?
I bought a 2012 C70 T5 a few months ago, and I'm starting to feel glad that I sprang for the CarMax extended warranty.
Do we have an analysis on root cause? Are we sure it's bad rings? Bad how, exactly? Cut the wrong size? Inferior alloy? Factory robot installed them wrong?
Do we have any information that would lend itself to identifying which engines have this problem and which do not?
5 others that came and went
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Resurrecting an OLD thread...
- I have owned P80, P2 cars, so familiar with Volvos.
- For the newer models, let's say 2012 T5 engine, does anyone know the EXACT ROOT causes of engine failure at 80K-120K?
I am asking bc I am looking ahead in case I need to buy a more recent models such as 2012+ cars.
- Also, what is the BEST engine/trans combo for 2012+ Volvos?
Thanks!
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Long oil drain intervals, especially with warm up idling, leads to sludge in oil ring grooves and the low tension rings will not power through the grip of the deposits. It is far from a sure failure. The repair is to put the same rings back in this engine. 3.2 and 3.0T engines are pretty dern good. There is a new oil spec, SN plus, that is developed for this oil sludge, stuck ring, oil consumption and detonation that can break center electrode of spark plug. Ceramic electrode bits can scratch the cylinder and then it is done. The electrode fracture is way less likely to occur on the 5 and 6 cylinder but is a bigger risk for the 4 cylinder Drive E motors. The higher compression used on direct injection pushes the detonation issue when the oil in combustion chamber.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
djtomr941 wrote: 23 Jan 2016, 18:18 This is a known issue on these cars. Volvo has issued TJ29871-2015-02-05. It has to do with oil burning in the S60 T5. If in Warranty they just fix, but the problem usually happens out of warranty. Goodwill is on a case by case basis. The TJ calls for replacing the piston rings and switching to full synthetic. If that doesn't work, they are replacing the engines. You can find more instances of this by just Googling. There appears to be something defective with the piston rings on this year/make/model. Could be why you are losing compression. Others are having clogged PCV's from blow by while others are just burning oil. If the PCV/breather gets clogged then it burns oil very quickly.
Jumping in here long after the first conversation. I'm understanding this was a 2012-only problem? What did they change in 2013? I'm kind of interested in a used V60, but obviously not a 2012!
https://images.firstcallonline.com/part ... 130443.pdf
