1990 740 gle gas delivery problem?
Ok thanks, I think the previous owner might have put b230 on it, can't be sure tho, guess I'll have to get a new set, the coil wire seems to have died, no resistance, been using a makeshift one for testing.
It starts and runs smooth for about a minute then wants to stall can keep it going with accelerator, then gets progressively worse till it just stalls, seems like I've had the same problem on a different car, not a volvo but can't remember what the fix was.
Does that sound like it could be the iac or tps?, was getting an 02 fault, cleared the diagnostic box, nothing came back but I only had it idling a couple times, put it thru the gears but didn't drive it, probably not enough activity to get a code? still fails the injector report test, the iac and the other thing reports but the red light just does a rapid blink for injector test, on test 3 of diagnostic box.
My rsr is kind of suspect, the connector is pretty much shot, wonder since it's a general purpose relay, if I can use an equivalent general purpose relay that has the same function, with spade terminals and connector, seems like the spade terminals have more contact and fit tighter than the small round ones, they are more readily available and therefore less expensive, it just seems like the round type are inferior to the spade type, what do you think?, been trying to figure out the exact specs. of the relay, thanks.
Unplugged the maf, started and it ran for about 4 minutes before stalling abruptly, that's about twice as long as with it plugged in. the way it runs smooth til it stalls, makes me think it isn't a vacuum leak. Wondering what bad sensor or bad sensor connection, could make it have symptoms like this? thanks.
- 29 Replies
- 4981 Views
Last post by 93Regina
- 2176 Views
Last post by lolafiona73
- 11 Replies
- 2022 Views
- 384 Views
Last post by cn90
- 1102 Views
