Thank you! Don’t you just love that filler cap/funnel? I can’t get over how much I enjoy what it offers.
That is exactly what I will do with mine, thanks again.
2002 volvo s60 2.4t PCV still blocked after service/replacement
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Chad, if I could thank you again, I would! I just did this today & my results paralleled yours. My PSI readings at the oil filler neck were effectively cut in half under boost.cfelberg wrote: 17 Feb 2020, 18:00 Just an update on this for informational purposes - I replaced the banjo bolt under the intake manifold with the udated one that has a check valve and it did lower the crankcase pressure. I was getting readings of -.05 Kpa at idle and up to 1.9 Kpa when under boost driving with the old banjo bolt. After replacing the banjo bolt I was reading -.25 Kpa at idle and .9 Kpa at boost when driving.
This is me eating my words.- Pete - wrote: 18 Feb 2020, 08:28
........ I find it hard to believe (not in a doubting manner to the OP!) that adding a banjo bolt with the check valve reduced crankcase PSI by half.
cfelberg wrote: 26 Feb 2020, 12:16 I used the filler cap. I ported a tube through the filler cap used with the volvo style funnel and cap combo as it conveniently has a hole already in it. I took readings initially from both the filler cap and dip stick tube and they were both the same.
This exact setup is how I did my test today. I am now thoroughly convinced that the updated banjo bolt does make a significant difference in valve cover PSI buildup. This is really important!
I took a before and after video of a digital manometer & will try to post it. My reading approximations, measured at oil filler, are below:
Old Banjo:
- Engine hot, idle @ 69.2*F ambient ~ -0.089 psi
- Engine hot, 2k rpms in 2nd gear 0mph ~ +0.085-0.1__ psi
- Engine hot, idle @ 70*F ambient ~ -0.037 psi
- Engine hot, 2k rpms in 2nd gear 0mph ~ +0.039-0.047 psi
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Reading vacuum at oil filler may be not very accurate because of moving camshaft lobe that creates a lot of disturbance. See in video how the gloves is soaked in, but the central part is raising under the boost. It is moved by the air pressure waves.
I also drilled a wider hole in PTC valve to have a better vacuum under the boost.
- 2898 Views
- 24 Replies
- 9534 Views
- 30 Replies
- 9532 Views
Last post by Ben850
- 1396 Views
Last post by precopster
- 1203 Views
Last post by Nismou20
