From briefly reading the thread your problem is with the CEL monitors
If that is the case, my state has a work around where you can take it to the main inspection place in the city. A government employed inspector will come out and look at the car, and see you've driven XXX miles and sign it off for that year, if that is the only thing holding you up. I know because I had to do this on a V70 I briefly owned.
Not saying NY has something similar, but it might be worth looking into.
How do you say goodbye? - S70, not passing NYS emissions...P0444 P0133 Sporadic
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
Hi everyone, have driven only 25 miles since I tried the Diode trick. No check engine lights. But monitors still not ready.
A few questions, can't seem to find these anymore...
When you solder in the diode:
- is EGR supposed to be "automatically" ready?
- how fast would one get a check engine light after doing the delete? (how do I know it's working?)
Semester is starting soon so and I need to swap struts and replace engine mounts in the S40... not sure I have much more time to devote to these machine.(God this clutch is so much more fun...)
Retired:
2015 Volvo S60, T5, 85K
The SAS delete code will come the next start after the code is set,so two start cycles. It’s looking for very lean Oxygen leveksin the oxygen sensor ( OXS) during cold start indicating excess air is getting pumped in by the pump. The diode is lowering the OXS voltage , we are lucky the system doesn’t check that the level ones back up after it turns the pump off.
Your EGR will take a long time to go ready because you don’t have one
Post up your monitor list and status!
- theWIFES_S70
Here are my monitors:
And here's my data... seems like I'm getting no reading from my 02 sensor, bank2:
The fun doesn't stop...
Retired:
- 12 Replies
- 2872 Views
Last post by matthew1
- 1308 Views
Last post by Jonboy74
- 1522 Views
Last post by 1998-S90-Owner
- 553 Views
Last post by jjmtjordan
- 1912 Views
Last post by alschnertz
