"Both functions , presence of 12V at relay, and logic enabling cranking, have to be functioning to crank "
I connected (Jumped temporarily) the termminal in engine fuse block (you call it remote starter ??) direct to the start terminal on the starter motor, normally a green wire. Then using key did crank the engine.
Does this mean making that jump connection permanent, with a new dedicated wire, Inside a new small size split loom, will get this system starting, excluding other starting problems of course.
My superficial understanding of complex Volvo systems is slowing me down big time
2000 S70 radiator core support replacement need help.
Without wiring diagrams we can’t really discuss this efficiently. If you jump the remote starter terminal in the white connector to a key position III ( crank position) source of 12V AND the PnP is I working order AND the green wire from PnP to starter solenoid terminal is good, that will work
Rocket99
- Year and Model: 2000 V70 XC
- Has thanked: 56 times
From what I can tell, the usual connection from key position 50 to the remote start terminal is intact as normal. I say that because, when I temporarily put jump wire from remote start terminal to signal wire spade connect on the starter, hooked up battery, then turning the ignition key did operate the starter ... crank the engine.
Also I again verified, there is no continuity between the remote start terminal and the green wire at starter. PNP switch is less than 2 yrs old, seemed to work right since it was installed. 12V seems present everywhere.
Thanks for your patience .... I've been learning as I go and you all have been golden to tolerate the stumbling
Ok. So it is either the PNP or the wiring from the relay to the starter , through the PNP, where the fault is located.
That bypass will let you start the car in any gear so be careful there
Rocket99
Okay
Now cranks real nice, no start
no gassy smell after much crank n crank, so FI isnt puming fuel in
no ominous dasbboard lights , ETS, SRS
I"m wondering: immobilizer?
Also,
no radiator installed, so coolant light is on
no engine fan relays installed
I"m wondering: immobilizer?. I saw Misha elsewhere another thread about no start , said connect battery but do not turn key on for 2 or 3 minutes .... may reset immobilizer ??
Also,
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No SRS & ETS lights with key in pos.II?
Do you have check engine light on with key in pos.II?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Ok...ecu is powered with key in pos.II.
But....a lot of control lights is missing with key in pos.II.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 4847 Views
Last post by volvolugnut
- 3274 Views
Last post by alschnertz
- 18 Replies
- 11330 Views
- 156 Views
- 11 Replies
- 9822 Views
