What non automotive projects and repairs are you doing?
Forum rules
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Re: What non automotive projects and repairs are you doing?
Our mid-century modern haus has a 1947 AO Smith old school big boiler for the hydronic system (in 1947!). It's I don't know how many thousands of btu's oversized, so maybe it didn't work that hard and lasted. Do you think maybe it's on borrowed time??
- Been thanked: 1000 times
It may be on some sort of time warp.
volvolugnutr
volvolugnutr
- Has thanked: 1500 times
- Been thanked: 3812 times
I have the guy who designed the PCV banjo screw chained to a bicycle generator making my electricity as punishment for his sins
Yesterday, I finally got the little Homelite chainsaw starting and running well. I cut down several small trees and larger bamboo stalks. As i was restarting, the starter rope started to bind. When I went to add more fuel mix, I found the pull handle was GONE. I retraced my path and found it with about 4 inches of cord attached.
I dug into my Homelite saw parts box with 3 mostly complete saws and found a body cover with good, working pull rope. Unfortunately, the body cover did not fit to the main body. So, I swapped the pull rope and clockspring from the mismatched cover to the old cover. Total time about 1 hour and no parts cost. Hoarder win!
More additions to creative wiring. Normally ok to use BX as a ground sheath, but you do have to tighten the nuts onto the sheath to ensure a good connection. Me, I’m going to attach that ground wire anyhow.abscate wrote: ↑08 Jul 2023, 10:45 Finding my way around the new house. HVAC, minor drain clog, burned 100 amp circuit , not too bad.
I did miss this class in NEC 601
If you run out of materials on a wiring job, you can omit a box pass through, wiring to outlet, and strain relief with a Hack-fire connection …
And this one off the web is puzzling for the neatness followed by complete code failure…
- 23813F1B-DB8C-4C13-8A16-201468CC0312.jpeg (482.69 KiB) Viewed 610 times
- 17754588-0E73-425C-B6B7-AB773267C12D.jpeg (243.23 KiB) Viewed 610 times
- BlackBart
^^^ wow.
This break I am trying to hang a painting on an old, very thin plaster wall.
Second project - fix a couple of low voltage track lights. Appears the electronic transformers have given up after 10 years. NLA of course.
Mouser Electronics is a good source for all things electrical.
https://www.mouser.com/c/power/transformers/
- Has thanked: 2652 times
- Been thanked: 1242 times
Every year or two the drain in my pocket sink stops draining fast, so water builds up when the tap is on. Years ago I tried Draino, very hot water, both, waiting, more Draino, etc. This did not work.
Then one day sometime after I got my Craftsman shop vac (also pocket sized
) I thought about trying to push the clog down the system. So I used the little shop vac and my rubber vacuum attachment adaptor (that fits perfectly over the drain) and did just that. Bingo. The other day I did it for the second time. Easy work.
Extra credit for shop vac bling.
volvolugnutr
volvolugnutr
