Vida CEM swapping
Quattrodag
Year and Model: 2006, XC90
Post by Quattrodag »
I collected the board but I can not read the pin code, tell me what is wrong, I collected it according to this scheme
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
Is pin 10 of teensy connected to CAN?
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Quattrodag wrote: 16 Apr 2021, 03:30 I collected the board but I can not read the pin code, tell me what is wrong, I collected it according to this scheme
That schematic is missing a jumper from Pin #4 to Pin #30 per the schematic, Pins 2 & 23 per the markings on the Teensy board.
The string of all zeros in the output indicates the jumper is what you are missing. It is the Latency detector, the beating heart of the whole cracking system.
Impedance mismatch from CAN transceivers to OBD connector. Get some twisted pair CAN Bus out of a junk car. The size and twist rate is part of the circuit balance.
I do not see the any 120Ω terminating resistors on the CAN transceivers. Unless they are installed backwards.
What is that in the corner of the picture where I placed an arrow?
Active
Past
T5Luke
Post by T5Luke »
When you try it on bench you should need 2 120 Ohm CAN resistors per line.
When you try in car you should need no resistor.
This resistors are to terminate. They kill the signal on the line. If you have less resistance the message stays longer on the line. If you have much resistance the message gets very fast "converted to heat" and is not long measureable on line. The specification writes about 2 ends with 120 Ohm, so when you measure can by multimeter you should measure 60 Ohm in total. Also verified with VTL useing just one 120 Ohm resistor has some effect on timing. If you have wrong resistor setup, this can cause background noise you won't need.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
RickHaleParker wrote: 16 Apr 2021, 04:13 That schematic is missing a jumper from Pin #4 to Pin #30 per the schematic
This was fixed long ago. People get the source code once and never update it :(
bosse
Year and Model: V50 -11
Has thanked: 9 times
Post by bosse »
Ground is missing.
RickHaleParker
vtl wrote: 16 Apr 2021, 05:19 This was fixed long ago. People get the source code once and never update it :(
I'm still trying to figure out how to use Github. It is slow going because the documentation is a joke.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 16 Apr 2021, 09:57 I'm still trying to figure out how to use Github. It is slow going because the documentation is a joke.
https://git-scm.com/book/en/v2
RickHaleParker
vtl wrote: 16 Apr 2021, 11:04 https://git-scm.com/book/en/v2
I'll add the 522 pages on Git to the 262 pages on Arduino C.
Active
Past
vtl
Post by vtl »
RickHaleParker wrote: 16 Apr 2021, 11:13
Ha-ha :) Git basic workflow is very simple. clone, checkout, pull, log, diff and that's about it for the occasional observer.
