putting a 960 TB on a N/A 850...
2volvoken
Year and Model: V70XC 1998
Post by 2volvoken »
Update on my earlier post...The parts from D. W. Volvo were delivered on saturday,installed today. The whole job took apx. an hour, to clean-up the t. body and install new plate....At start-up I noticed a better idle, even a tad lower rpm..The car is still not real fast off the line, the the throttle response is diffinetly better. If your going to "really" clean the throttle body on your NA engine it is worth the 12.70...I have included the parts #'s off the invoice.....3501603-9 throttle disc.
943781-5 screw
9135990-1 gasket
Thanks to all thanks to D.W. Volvo!
'93 850GLT na 155,000 '98 V70XC 115,000 '99 C70 126,000
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
beewerks wrote:Hey guys, not sure if this thread is still alive, but I was wondering if anyone knows of a place online where I can buy just the 960 throttleplate?
Why can't you just cut the plastic piece off the 850 plate?
2volvoken
Post by 2volvoken »
If you remove the plastic you will be left with a hole in the plate itself....that will screw up the idle,among other things....call up Darrell Waltrip Volvo they will be glad to help you out....
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
hey guys...this might seem like a stupid question...but how do you get the throttle body off?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
No problem- not a stupid question at all...take the hose to it off and then you'll find 4 10mm screws holding it on...just undo them and it pops right off...make sure you use a new gasket when reinstalling it...I don't have a torque wrench that small so I just retorque the German way- Gootandtite.
polskamafia mjl
haha, ok sounds good. I don't have a torque wrench either but gootantite sounds good to me. I'll have to wait until monday to do any work because I work all weekend, so I'll let you know if I run into any problems.
polskamafia mjl
Another stupid question, I'm afraid... :(
Can someone take a look at this picture and tell me if this is infact the throttle body?
http://s594.photobucket.com/albums/tt26 ... engine.jpg
This isn't a pic of my engine bay, I have a GLT not a turbo, but it's all the same...
No, that's just the throttle cover...take it off...then you see where the turbo hose is to the right of it? That will have to come off to give you room- then you'll see another turbo hose connected directly to the inlet of the throttle body- take it off...and the square thingy with a round hole in it is your throttle body...hope this helps. Your surrounding area might look a bit different from this picture (this is on an non-turbo) but the round opening where the large hose attaches and square throttle body look essentially the same: Image
vegasjetskier
850ThrottleBodyReplacement1996.pdf
(99.3 KiB) Downloaded 491 times
polskamafia mjl
Thanks guys. I have a non-turbo as well, that picture was something I found online. haha I'm replacing my axles this tuesday after class so I'll probably take care of the air box mod and then take a look at the throttle body. I'm trying to find a junkyard near my house that has a 960 so I can get the throttle plate. MIJ, you mentioned that I needed to get a new gasket I think...can I order that from FCP or something?
