What has failed on your 1992-2000 FWD or AWD Volvo?
02 sensor
150
2%
a/c clutch, compressor, accumulator tank
89
1%
a/c evaporator, purge valve, pressure switch
54
1%
a/c receiver-drier
21
0%
ABS module
246
4%
airguide, skidplate
63
1%
alarm status indicator
13
0%
alternator
80
1%
ball joints
142
2%
battery cable
43
1%
bevel gear
19
0%
brake booster check valve
5
0%
brake caliper
84
1%
brake hoses
54
1%
cabin temperature sensor
26
0%
camshaft position sensor
49
1%
cargo cover on wagons
22
0%
center arm rest, release
50
1%
center hood latch, extension lever
37
1%
control arm
113
2%
coolant expansion tank, cap
112
2%
coolant hoses and clamps
91
1%
crank seal
23
0%
crank sensor
11
0%
cruise control, linkage at the gas pedal
26
0%
cup holders
170
3%
cv boots, axles
184
3%
dash ungluing
96
1%
defroster plate
12
0%
door catch, check strap, hinge
123
2%
door lock actuator
100
2%
door panel ungluing
122
2%
door-lock switch
54
1%
driveshaft
41
1%
ECC electronic climate control
46
1%
ECT engine coolant temperature sensor
54
1%
ECU air tube
34
1%
emissions air pump SAS, relay, valve
64
1%
engine mounts
213
3%
ETM
61
1%
exhaust hanger
59
1%
FPR fuel pressure regulator
10
0%
front washer pump
11
0%
fuel door latch
54
1%
fuel pump, relay
53
1%
glovebox lock
44
1%
grill retaining clips
25
0%
head gasket
24
0%
headliner ungluing
80
1%
heated seats, seat t-stat, seat wiring
70
1%
heater core, blower, resistor, lines
155
2%
IAC idle air control valve
17
0%
ignition coil, coil pack
67
1%
ignition switch, cylinder
50
1%
interior light dimmer
9
0%
interior switch, info switch
24
0%
keyless entry, remote or car
64
1%
MAF mass airflow sensor
123
2%
odometer gear
109
2%
outdoor temperature sensor
16
0%
parking brake cable
68
1%
PCV system
179
3%
PNP switch
40
1%
power antenna, cable
83
1%
power door locks
53
1%
power steering pump
18
0%
power steering rack
43
1%
power window module
27
0%
power window motor
20
0%
power window switch
75
1%
radiator
144
2%
radio, cd changer
58
1%
rear hatch latch
35
1%
rear main seal
47
1%
rear washer pump
42
1%
seat adjustment switch
33
1%
seat belt release
36
1%
seat cable
20
0%
seat leather, cloth surface
133
2%
shift solenoid
16
0%
shift-lock microswitch
40
1%
signal flasher relay
9
0%
speakers, speaker wires
63
1%
spring seats
67
1%
starter
40
1%
steering wheel
15
0%
strut mount
136
2%
sun visors
52
1%
sunroof
43
1%
sway bar link, end link, tie rod
152
2%
tailgate or trunk strut
126
2%
thermostat
101
2%
throttle control linkage
9
0%
timing cover seal
7
0%
transmission
42
1%
turbo oil cooler line, oil return, gasket, o-ring
69
1%
vacuum lines, elbows
145
2%
wheel bearing
93
1%
windshield washer tank
20
0%
windshield wiper arm, post
48
1%
Total votes: 6508
dosbricks
Been thanked: 4 times
Post by dosbricks »
With 17 years of owning these two P2s, I was able to check off about 80% of the list--90% of those repairs done with my labor.
So that leaves about 20% of the list in the things-that-could-go-wrong-next category. I think I'll get my doctor to prescribe something for depression. :|
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
dosbricks wrote:With 17 years of owning these two P2s...
P80 :wink:
Also -> Amazon link
dosbricks
Post by dosbricks »
My bad. :oops: I must be thinking about a newer ride again.
foresthump
Year and Model: C70 2001
Post by foresthump »
front cam seals at 119,ooo miles. Repair shop said this was not unusual. Total cost for ALL seals, camgear, timing chain, serpentine belt , tentioner, oil and filter and, unrelated...replaced the leaking power steering resevoir and hose...$1600.00!!!
This was a catastrophic failure, not a little leak. Huge amount of oil blew out all at once.
t5turbo1
Year and Model: 1999 S70 T5
Post by t5turbo1 »
Dash cracked from firewall. Afraid to tackle that job by myself. Don’t want to break something else in the process.
