Defeating the torque limit request on the Volvo 850 Turbo
Defeating the torque limit request on the Volvo 850 Turbo - TCM Signals
ARD-Lucky wrote:For those really interested I can turn off the torque limitation in auto trans ECU's if you like... however once you drive an ECU with this turned off you might change your mind. I know I did.
The car becomes very jumpy to throttle input and wheel spin is a serious issues with this turned off.
Perhaps the OP would be interested in doing a before and after write up? I'd donate the tuning at no cost
So I'm assuming that there's no hope or possibility for just a decreased 1st gear torque limitation??
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
When I had 94-98 850 and s/v70 company cars on which I did the signal interrupt, I had to ease into the throttle on a speedy take off or I'd get straight line wheel spin. The more onerous problem was driving normally and pulling into the street from parking lots. The unloading of the inside front wheel would allow normal throttle application to break traction.
I had a couple of manual trans models and they have no torque limiting and it was not an issue with those. The torque amplification via torque converter was greater than I ever anticipated.
- Has thanked: 2856 times
- Been thanked: 1332 times
Sounds like the defeat causes embarrassing situations in parking lots and low speed stuff.
I think this would be something you'd want a dash switch for, which leads us back to Jimmy's 1990s physical mod... help, I want to get off this ride!
Or...
Lucky, can Arduino boards or Raspberri Pi's talk to (your ARD, flashed) ECUs? Can you defeat this in realtime, given a cabin interface?
Im curious if rather than a simple on/off style switch if you could splice in a variable switch, like what light dimmers use. This way maybe you could control the level of 1st gear torque between stock and complete tire roasting
That would be great, but only works if it allows variable input. My guess from what I know about ~1995 auto technology, is that it's a bit field, meaning on or off.
Lucky will know...
Lucky will know...
- 2382 Views
Last post by waffleshill
- 3933 Views
Last post by Integrexman
- 3938 Views
Last post by goldmandan
- 18 Replies
- 9718 Views
Last post by Orchid70
- 1107 Views
Last post by cn90
